What exactly is a Speed Density Tune
Old Jan 29, 2012 | 02:13 PM
RENE'S RAGE's Avatar
Default What exactly is a Speed Density Tune
Could someone explain it.
Also what sensors do you keep and which ones to get rid of.
I know the MAF goes, what about the o2's, knock sensors, MAP, IAT, ect.
Thanks
Old Jan 29, 2012 | 02:49 PM
MUSTANGBRKR02's Avatar
George
Normally everything stays in a SD tune unless you are running a Open loop SD tune then your o2's go also. SD tunes are usually used in FI builds and stroker high HP application.
There is a ton of threads as to what is better etc in this section and online if you want to read in detail.
Old Jan 29, 2012 | 04:04 PM
Thanks Bill
I want be running a MAF with this Super Victor and 4150 TB. Race only car.
I've read alot on the SD tunes, but still confused alittle. Most people are worried about idle and street driveability with SD tunes, that I've read. I don't care about driveability.
This car will stay between 5000 to 7000 rpms most of it's time.
Old Jan 29, 2012 | 06:23 PM
Sounds like SD is for you then lol
Old Jan 30, 2012 | 04:54 AM
edcmat-l1's Avatar
Originally Posted by RENE'S RAGE
Thanks Bill
If done properly, you shouldn't be able to tell the difference between MAF and SD. I've tuned several carb style throttle body cars. They run real well for as radical as they are.
Old Jan 30, 2012 | 02:04 PM
redtan's Avatar
A good SD tune does not lack idle smoothness and street driveability whatsoever over a MAF tune.
Old Jan 30, 2012 | 03:15 PM
foff667's Avatar
LS1TECH Sponsor
http://www.hptuners.com/forum/showthread.php?t=8994
Old Jan 31, 2012 | 05:05 PM
Thanks everyone.
Great info in this thread.
Old Feb 1, 2012 | 02:01 AM
Predator's Avatar
Great information in this thread that crystalizes why the hybrid tuning system is currently best for my street car application.
Old Feb 1, 2012 | 03:01 AM
The Dragon's Avatar
Thumbs up
Originally Posted by redtan
a good sd tune does not lack idle smoothness and street driveability whatsoever over a maf tune.
Exactly.
