LS3 vs LS7 exhaust flange location?
Old 01-29-2012, 02:27 PM
camaroandreas's Avatar
Default LS3 vs LS7 exhaust flange location?
Can i build my turbo manifolds with LS3 heads then swap to World LS7 heads? Are they located at the same place?
I want everything to fit
Old 01-29-2012, 02:51 PM
Louis's Avatar
Bolt holes are in the same location, flange angle is the same, the port is .060 (1.5mm) higher in the LS7, everything else is spot on the same.
EDIT- Missed that they were world products heads.... that Im not sure, but as far as Im aware, they are direct replacement for stock OEM LS7 heads.
Louis
Old 01-29-2012, 03:07 PM
Thank you for the information. I think world also has the stock LS7 location. Now i can start to build
Quick Reply: LS3 vs LS7 exhaust flange location?
