LS3 vs LS7 exhaust flange location?
Can i build my turbo manifolds with LS3 heads then swap to World LS7 heads? Are they located at the same place?
I want everything to fit
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Bolt holes are in the same location, flange angle is the same, the port is .060 (1.5mm) higher in the LS7, everything else is spot on the same.
EDIT- Missed that they were world products heads.... that Im not sure, but as far as Im aware, they are direct replacement for stock OEM LS7 heads.
Louis
Louis
