Most gentle lobe from comp?? LSL, XE, LSK?? Need help
I need help with te most streetable lobe from comp. Im doing either 226/236, around .600 lift or 227/235 with about the same lift on 110LSA , 110ICL. Just need best street friendly type of lobe
I just want a car i can drive 300 miles one way in if i feel like it. Streetable, but I CAN drive a stick (no pun intended) im looking at a 110lsa and icl. So im stuck between LSL and XE
Read this. pat G explains it. it is basicly a LSL lobe with softer seats. ideal for Exhaust lobes and high ratio rocker arms
https://ls1tech.com/forums/generatio...lxl-lobes.html
Im thinkin the 227/235 LSL .614/.621 on 110LSA 110ICL, this isn my daily, but i like to drive it. It should also utilize my ported 806's with 290cfm flow as well. I will be using my new PRC .660 lift dual springs. What are your thoughts guys?? Should have a NASTY idle (what i want) and have good power and dependability. I am in an M6 too BTW
I run a similar cam, also with the LSL lobes (227/231, 111lsa +2) it'll pull hard to 7k (did it 1 time) with very little hp drop, so I'd recommend running some advance. Further more the LSL lobes aren't really a quiet lobe at all, so I'd recommend running a 234 LXL lobe for the exhaust, instead of the 235 LSL lobes. I've also been considering going with the another cam with LSL lobes on the intake side, but with LXL lobes on the exhaust side for a quieter valvetrain than I have now.
