FS: SDCE aluminum dual fan shroud with SPAL fans, made for Procharger fitting!
Category: Engine - Power Adders
Price: $300
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird
Location (State): CA
Item Condition: Used
Engine: LS2/LS3/LS7/L92/LS9, LS1/LS6
LS Engine?: Fits LS Engine
Item for sale is a SDCE brand aluminum fan shroud specifically designed to be used with a Procharger application. This shroud allows you to have to cooling benefit of two SPAL fans that can pull air over the whole surface of the radiator instead of just isolated locations with fans only. I have used this set up for about 6yrs now without issues and in the California heat, even with the A/C on, it did the trick. Fits perfect with the Procharger intake hat. I used to have the dual spal setup with the spal shroud but needed something more with the CA heat.
This was used on my 02 35th Anniversary SS.... while the time line was about 6yrs old the car is barely driven. Id say this setup only has 15k miles on it.
I no longer need this as Ive gone to a stand up Griffin to make room for a F1C.
Retail is $400 + shipping. Im asking $300 + shipping.
If youre interested I can include a BRAND NEW 160* tstat for $35. It was never used as I went to a Aster bracket and had to replace the water pump on my new motor.
Thanks for looking.
o man i love this setup , i wish i had the cash for this , i cant stand my single fan setup , sucks with the ac on . wish you were closer , maybe work a trade plus cash , but o well
good luck bump .
good luck bump .
Let me do some measuring on my car. I only have 6" from the face of my intercooler to the water pump, and I have to fit a radiator and fans there. The Griffith radiator I am looking at has 2 1½" tubes (3¼" core thickness) so that doesn't leave much room for the fans. It looks like your larger fan will be right in front of my Meziere water inlet too.
