Keep my motor or build a lq9?
Old 01-31-2012, 09:52 AM
1998MysticZ28's Avatar
Default Keep my motor or build a lq9?
Hey guys, I plan on spraying the car Im just curious if my motor would be good enough or should I just build a Lq9.
My motor
Changing things up on the car. Selling the motor, and trans
Motor is a built 347
-LS6 block
-new clevite mains and rod bearings
-new eagle rods
-fresh GM crank
-ARP main stud kit
-diamond pistons -2cc valve reliefs
-new GM file fit rings
-LS6 valley tray mod and valley cover
-LS6 Intake w/ ported TB
-PRC stg 2.5 Ported Heads
-Custom Grind Cam 232/236 114 LSA
Old 01-31-2012, 12:49 PM
Sofls1's Avatar
What are your goals? I don't see why you couldn't spray that engine, but it all depends on what you want to do.
Old 01-31-2012, 01:02 PM
Would like to run bottom tens those are my goals
Old 01-31-2012, 01:44 PM
87silverbullet's Avatar
Man, spray that motor and get rolling! That setup with a good converter on a 175 shot will get you there easy.
I have seen cars with less cam and head than what you posted run 10.50's all day on a 150 shot.
Old 01-31-2012, 03:41 PM
Sofls1's Avatar
Spray it and don't look back. Depending on the rest of your setup, you should be able to do that on a 150-200 shot.
Old 01-31-2012, 05:55 PM
N2RACINGLS1's's Avatar
Your car runs high 10's NA now correct. I would think nitrous would get you where you want to be with only a 150 to 175 HP shot.
N2
Old 01-31-2012, 07:44 PM
Negative my PB was 12.1 at 113
Right now I have a Performabuilt 60e stg 2 with their 3600 stall I might swap out for a 400 though. Also looking for a 9'
Old 02-01-2012, 09:48 AM
You should be good with their stage 2. I don't see the need for a Th400 but you will need that 9".
