Do these numbers seem right?
2004 GTO (LS1)
Cam: Comp 54-444-11 (224/230 .581, .592, 114) XER273HR-14
Heads: PRC Stage 2.5 LS6 CNC Ported Heads milled for 11:1
Headers: Pacesetters 1.75", no cats
3200 RPM Converter
Cold Air
Tuned
I was told my numbers would be higher with a less "loose" converter.
I need to ask the shop why the run didn't start < 4200 RPM. I would expect to see numbers starting around 2k or so right?
Max Power: 374
Max Torque: 352
I was really hoping to break into the magic 400s for HP. FYI, this is my daily driverr.
3200 RPM Converter
Cold Air
Tuned
Max Power: 374
Max Torque: 352
Unless you have HPTuners or something and lock the car into a certain gear through the interface.
Youve never operated a chassis dyno before have you? if you want a pull from 2k, you have to have a manual car. Automatics are tougher, not only does the torque converter flash, but the transmission wants to downshift.
I just wasn't sure if it was common to see it start at 4k. If the car was tuned at the same time, wouldn't they lock it into a gear and do the pull, or is that not a common practice?
