1984 BMW 318i vs 1999 ws6
1984 BMW 318i - swapped in a 1995 s50 motor (M3) with larger MAF, headers, throttle body, and a tune. Weighs about 2300lbs. 5 speed. 4:10 rear. I think the previous owner dyno'd it around 280hp.
1999 WS6 - stock motor. Slp lid and cat back exhaust. LS7 clutch. Bunch of suspension stuff. weighs about 3600lbs Mustang dyno'd 303hp ?
weather: 35 degrees clear
3 runs. Only one semi-good run: 40 roll to 100ish
ws6 missed 3rd one run, BMW missed 5th another.
BMW starts in 3rd, ws6 in 2nd. WS6 pulls ahead half a car until BMW shifts to 4th. Pretty much remain even to 90 or so. BMW wins with rear tire at ws6 nose.
ws6 tried starting in first but rpms were too high.
Didn't do any digs yet, we just wanted to see what it would do real quick.
I put the video in cause I know you all like them but it is not very good. I need a new camera person. This is the only video where you could see the bmw but is not the best race.
http://youtu.be/U4dwnK_Ng4w
Coming from the guy who drives a GTO, I don't think your opinion carries a lot of weight.
The s52 block was the updated version (kinda like the ls1 and ls6 for comparison).
The new motor weighs less and his car weighs right around 2300lbs. thats about 1000lbs less than the 95 m3. He did it because he ran across a good deal for a much better engine to replace the one that was going to come apart any day.
and to 2ssarme: to each his own. most people probably ask why you created that thing in your sig. hopefully your answer is because its what you like and wanted to do.
also his intention was to make his car more reliable while also getting more power in his daily driver. His "modded" car is a 1986 IROC that has a bunch of engine and suspension work done to it.
That BMW weighs more than 2300 unless it's totally gutted.....and op you need to go work on your car. That was a sad showing. S50's in a e36 ran low 14's. That guy may make it to a low 13 but that's about it. Hell I think s50's was only rated @ 280....and they have mutiple tb's.
I've had e36 M3 before with s50 engine in it, its quick for what it is, and it handles REALLY well. Took it to the track once and ran 14.5 @ 101ish. Not really a good race for an fbody though in the stock form
That BMW weighs more than 2300 unless it's totally gutted.....and op you need to go work on your car. That was a sad showing. S50's in a e36 ran low 14's. That guy may make it to a low 13 but that's about it. Hell I think s50's was only rated @ 280....and they have multiple tb's.
and yea my car does need work, apparently its the slowest trans am ever.
I have a e30 M3 I've been working on for a guy. It has a s54 engine in it, gutted race car that I have been trying to get weight out of and I will be lucky if it comes in under 2200lb.
What year and model e30 is it? I realize it's gutted but the newer the heavier it became. Also an 84 318i base model is going to weigh less than any of the 325 models (325i/e/es/is/ix). And the s54 I a much newer, more powerful motor with individual throttle bodies. That will be a fast car if it can get traction. Is he road racing it?
Well kinda, he's not really hardcore but he has enough money to have nice stuff. I worked ar ptg for 15yrs. Another friend worked there for 6-8yrs building engines and when he quit he built a shop and now builds race engines. He will duplicate one of the 3.4 I 6's for this car.....hopefully with some improvements.
