Which "ECM Type" do I use in WinALDL for 94 trans am auto?
I've never used that program but I don't see that vehicle as even being supported.
http://winaldl.joby.se/aldldata.htm
Why don't you just use TTS Datamaster?
You can datalog with Datamaster 20 times before you have to pay anything. Another one that I have never used but hear about is freescan.
http://andywhittaker.com/ECU/FreeSca...0/Default.aspx
Look here for more.
http://www.aldlcable.com/sc/pages.asp?pageid=20
Look here for more.
I have Datamasters from TTS now and I cant get it to work. I can get a link to the PCM. I have all the right settings, usb driver latency to 1mS latency and changes the software data settings from 190-205, point by point as per the manual. I have the Moates.net ALDU1 cable and box with the open and 10 ohm switch. I contacted them and I am waiting for a reply from them. Was hoping to run it by every on here and gain some insight.
