Why use 5.3 heads?
Old 03-19-2004, 08:32 PM
Mack'sZ28's Avatar
Default Why use 5.3 heads?
Why are alot of people going with the 5.3 heads instead of ls1 heads?
Old 03-19-2004, 08:38 PM
Fast SS on TNT's Avatar
Higher compression ratio. More power (insert grunt).
Old 03-19-2004, 08:45 PM
Extinct SS's Avatar
What does the compression get raised too??
Old 03-19-2004, 08:46 PM
Mack'sZ28's Avatar
Isn't cheaper to get the 5.7 heads milled?
Old 03-19-2004, 08:56 PM
Spellbound's Avatar
You can mill them, but your push rod length will be affected by how much you mill. With the 5.3's, you can get the compression without milling and keep your stock length push rods.
Old 03-19-2004, 09:14 PM
mike m's Avatar
plus 5.3 heads out flow the 5.7 heads.
Old 03-19-2004, 09:58 PM
jrp
SN95 Director
jrp's Avatar
how is that when the ports are the same? most everything i've seen show the 5.3's and 5.7's flow the same with a comparable port job. only thing the 5.3 has over the 5.7 is the 61.1 CC for the added CR.
Old 03-20-2004, 02:35 PM
Mack'sZ28's Avatar
How much does 5.3 heads run?
Old 03-20-2004, 04:52 PM
M6HuggerSS's Avatar
stage 2 heads at PATRIOT are only $1,295.00 And thats a complete CNC port job, there double gold springs, 2.02/1.57 valves, titainium retainers, and new viton seals!
Old 03-20-2004, 05:00 PM
Tally TransAm's Avatar
you get higher compression with less milling so you can keep maximum p-v clearance
Old 03-20-2004, 05:04 PM
Flyer's Avatar
I've got a spare set I'll trade someone. Stock for stock. I wanna lower my compression, so the ls1 heads would work out good for me.
FYI, it moves the 5.3 from 9.5:1 to ~9.1:1
Old 03-20-2004, 07:24 PM
JZ'sTA's Avatar
A few headporters I have talked to say the 5.3's flow a tiny bit better after they finish them. The difference is very little (1-2cfm's from what I gather) Also a stock LS1 is 10:1 CR by adding the 5.3's you will have around 10.8:1 CR. Also you can add a bigger cam because you dont have to mill the heads for the added Compression.
If lower compression is what you want you need to try and trade the 5.3's for the 6.0 truck heads. The 6.0 heads will take a stcok LS1 from 10:1 down to 9.4ish:1 CR. Works greak for the FI guys wanting to run 10psi. Plus the 6.0 heads are better in almost every way then the 5.7 LS1 heads and the 5.3's
Old 03-20-2004, 07:40 PM
FASTONE's Avatar
Whats the biggest valves you can put in 5.3s, I know you have to put new valveseats ,can you put 2.05 and 1.6s??Bore will be 4.030 also are 5.3s 61cc,s?How much can you mill a 5.3?
Old 03-21-2004, 12:12 AM
WS6 #3392's Avatar
I love the 5.3 heads. They flow 300 cfm at .600. TEA is the place to ask the questions about what you can do with the 5.3 heads. Look in my sig and you can see what I got with them.
Old 03-21-2004, 05:09 PM
Eastern Bowtie's Avatar
What kind of numbers can be obtained with a pair of ported/polished 5.3's with big valves and all the right hardware. Matched with the right cam and long tubes of course. Is 400+ RWHP unreasonable?
Old 03-21-2004, 05:24 PM
400+ is easily obtainable, people are getting upwards of 430-440 hp. a few might be over 450 but not sure
tea, as, patriot all offer nice 5.3's
Old 03-21-2004, 06:36 PM
ls1/7's Avatar
if you go with a nice size cam and a set of stage 2 5.3 heads will it be ok to spray like 150 shot on that compression? i know ill have to retard the timing just wondering if it would be ok
Old 03-22-2004, 08:44 AM
bigoneZ28's Avatar
Good question..I would like to know as well.
Old 03-22-2004, 10:43 AM
JZ'sTA's Avatar
Will be fine as long as you can get enough fuel. (injectors/pump might be needed)
93 octane would should work just fine.
People have been milling 5.7 for forever and spraying. Many people spray the LS6 heads which are 10.5 CR the little extra compression wont hurt a thing.
Old 03-22-2004, 06:06 PM
black99ta's Avatar
I was thinking of putting 5.3's on my TA. Can you still run pump gas with the 10.8 CR (with a stock cam)? Does anyone know what kind of power is added by just adding 5.3s?
