Generation IV Internal Engine - dry sump pics? which peterson tank u runnin?
7second
02-12-2012, 10:13 AM
any engine pics with dry sumps? which peterson tank you guys runnin? I'm thinkin the 1.5gal drag race one but dunno if 6 qts is enough for street use
Firehawk441
02-12-2012, 04:00 PM
I use the moroso tank with an ARE pump and pan
http://i557.photobucket.com/albums/ss17/firehawk441/IM000442.jpg
http://i557.photobucket.com/albums/ss17/firehawk441/IM000441.jpg
http://i557.photobucket.com/albums/ss17/firehawk441/IM000439.jpg
7second
02-12-2012, 05:23 PM
nice, who makes that alternator bracket? bmr?
Firehawk441
02-12-2012, 05:52 PM
Correct. BMR. I had to remove .250" from it to compensate for the motor plate.
Louis
02-13-2012, 06:18 PM
Id use more than the 1.5 gallon. Even though the stock pan holds that, Id look into atleast an 8 quart setup.
Firehawk441
02-13-2012, 06:56 PM
1.5 gallon tank works fine for me. :burn:
Gray86hatch
02-13-2012, 08:39 PM
Whos motor plate is that
Tim
Firehawk441
02-14-2012, 05:41 AM
Tim
KTS Race Cars.
http://www.ktsracecars.com/motorplates.htm
7second
02-14-2012, 12:54 PM
I like the petersondrag tank with integrated catch can. But it only holds 6quarts. I think atleast 2 gal would be better with a turbo motor and heat. Guess running a seperate catch can isnt bad
studderin
02-14-2012, 03:01 PM
No Tstat?
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
