Anyone using solid engine & frame mounts for their swap?
I am gonna go solid front and rears, when I get that far...still doing t56 conversion and locating header/oil pan combo.
Biggest problem is the transmission of vibrations throughout the chassis. Has a tendency to reverberate and drone at certain RPM. I'd go with a poly setup. You can make the plates for the motor, and then use something like this
http://suspension.com/4-bar.htm
And then weld that to your frame / k member or whatever.
my .02
my .02
