What throttle cable bracket with FAST 102mm?
Old 02-16-2012, 12:36 PM
parks450's Avatar
Default What throttle cable bracket with FAST 102mm?
Like it states what throttle cable brackets are you guys using with your 102 intakes? A pic or a part # would be helpful to. Its for the ls1 style 102 if that helps, thanks.
The following users liked this post:
Rat Chevelle (03-21-2022)
Old 02-16-2012, 01:52 PM
Undertow74's Avatar
The Stock Bracket
Old 02-16-2012, 01:55 PM
VandykeT/A's Avatar
Yep I'm running the stock one.
Old 02-16-2012, 03:16 PM
parks450's Avatar
Hmmm ok this is in my s10 so I'll see if one from a Camaro will work.
Old 07-12-2013, 04:01 PM
ShredSled's Avatar
Did you ever figure out what bracket works with the LSXR?
Is it a camaro cable bracket that bolts right up???
like this:
http://www.ebay.com/itm/97-04-LS1-LS6-Camaro-Corvette-Throttle-Cable-Bracket-/360487128789?pt=Motors_Car_Truck_Parts_Accessories&hash=item53eeb50ed5&vxp=mtr
I'm wondering if I should just scoop up one of those, or get the Scoggin Dickey SD90BRKT that bolts up to the back of a Nick Williams Throttle body?
Old 07-12-2013, 05:16 PM
Blackpanther99's Avatar
Should work. Not 100% sure though.
Old 07-12-2013, 08:28 PM
ShredSled's Avatar
Alright, have one on the way... if it doesn't work I'll have to get that Scoggin Dickey NW bracket.
Also just realized my LSXR doesn't have any threads where I imagine this bracket would go. Guess I'll have to find some nuts that drop in the slots.
Hey parks450, just realized you were in the Mitten, where about?
Have any tips for an LSXR install on a gen III?
I'm a bit baffled on which ports to use and where to put sensors, etc... I think I might have to find some sort of block offs for some of the open ports in mine...??
Old 07-12-2013, 09:27 PM
Sorry to go off topic man but you have one clean *** single cab! Props!
Old 07-12-2013, 09:32 PM
ShredSled's Avatar
Haha thanks man. And she sounds better than she looks too! I kinda like the somewhat OEM+ look it has, nothing too extreme lowrider or billet, almost like something GM could have done if they chose to make a real sport truck! 4wd for gnarly street launches too.
Old 03-10-2015, 12:02 PM
themealonwheels's Avatar
Hey guys, let me bring this one back... what bracket do I use for an LSXRT intake? I've got one on the way for my swap and my harness is already set up for drive by cable. So what throttle cable bracket do I use?
Old 03-11-2015, 07:53 PM
ShredSled's Avatar
I got the factory F-body bracket to work. I had to use some large spacers/washers (don't remember dimensions) and much longer bolts to get it far enough away from the intake to clear cleanly. And if I remember correctly I had to do some Dremel work on the openings to match the cable clips on my cables for the truck... got it all to work fine though, with no issues.
Old 03-02-2020, 03:44 PM
Fah Cue's Avatar
I don't see any other way this can go on
Not only will it not go on, but if it did it's going to cover the front MAP Port, which I've drilled out.
So what gives. Am I really going to have to take this intake completely apart to drill the rear MAP Port/fill the front and Dremel this intake to get this bracket to fit.
Old 03-04-2020, 02:14 PM
Bspeck82's Avatar
Stock map location is on the rear so unless you were planning on modifying or extending that part of the harness it wouldnt work anyways. (If you got an fbody) the fast the stock bracket should work I see them on Ebay for 25 bucks if you ditched yours. Supposedly that sdpc bracket was designed for NW and fast intakes....
https://sdparts.com/i-22714833-sdpc-sd90brkt-ls-throttle-cable-bracket.html
its labeled as a 90 in the part URL. Idk of there is a diff of overall height of the mouth if the intakes but I'd imagine the 102 is overall bigger of course.
Old 03-12-2020, 06:46 PM
LilJayV10's Avatar
Maaaybe is should to in front of the the throttle body.
Seriously, how in the hell did you ever think setup that was going to work?
G Atsma (03-13-2020)
Quick Reply: What throttle cable bracket with FAST 102mm?
