prc ls6 2.5 or TF 220's
I was contemplating this exact same thing a while back, and ended up getting a set of worked over tfs as cast 220's.
I ended up buying a slightly used set of ported ls2 style tfs 220's for a damn good deal. They already had port work, bigger ferrea valves, and the valve angle is 13.5* so it helps with ptv. I think the aftermarket casting is the way to go, and I'm glad I made the decision, as I feel I would have been dissapointed with the prcs in comparison to these tfs.
If I were to do it again, I'd say go big or go home. My next set of heads will probably be a set of mamofied AFRs.
There is nothing wrong with properly ported factory castings. And aftermarket stuff can be run with factory valvetrain if the correct hardware is installed. As for push rods. They should be measured and replaced with the right length anytime heads,cam are changed. The main advantage your going to have is better PTV clearance. From personal experience the PRC 2.5 LS6 head is better than stock. But the TF220 is better than the other. But PRC has a 227 head and a new 220 head coming out that should be considered for best bang for the buck.
Have you looked at the MAST LS3 small bore heads? A lot more $$ than either of the heads you picked out but you can get an LS3 intake for a ton less than a FAST. Flow numbers are impressive - curious how they would do on a stock displacement LS1.
The PRC as cast heads are currently in the machining stage. In about 2 weeks, they will be a few sets installed on cars. If all goes well, production will start then.
I was just trying to get the best bang for the buck. Trying to keep on a $3000 budget for a head/cam build but every time I look for options the price goes up. I just don't want to buy ok heads and kick myself down the road. It's hard for me to spend $2400+ on premium heads. Maybe I should wait ad see what prc 220's will perform and price at. If they priced the prc's at the same or bellow the tf 220's cast and they performed better they would sell very well. I don't need the best out there. Just something that is worth the time and money.
Whats a trip is that i tried to find searches on cars in action on the street with TFS heads. All i ever seem to find is "Go with TFS", or its a vid of TFS on the dyno, or an all out drag car.
As much as we all say TFS, TFS i wanna see these heads in action on the street. I havent found any on this site.
With PRC you see lots of vids of these heads on cars running fast on the street. I would not hesitate to buy some PRC seeing some PRC 5.3 heads, 228 cam car smashing a 03-04 cobra. That says alot guys.
