G body fuel lines
G body fuel lines
I recently picked up a 87 T Type fuel tank for cheap would it be wise to pick up the factory fuel lines as well? My GP originally came with a carbed 305 and the fuel lines exit on the passenger side, The T Type's does the same except they go under the engine cross member and exit at the driver's side. Would those work with my 99 Firebird LS1 and my 85 GP? Thanks!
Yeah my original carbed fuel lines probably wont work but exit at the passenger side, though the vent return line is on the drivers side.The t-type original lines end up on the drivers side both the fuel and return. My stock LS1 has the fuel inlet on the drivers side if i am correct... I plan on using the Vette regulator/filter and am eying a Racetronix pump..
I am CONFUSED!!! SO i am going to use the T type tank with a racetronix pump should i get the one with AN fittings or the push lock ones? I am planning on using the nylon lines .... or whatever one is cheaper or easier to plumb I would prefer to use the most OE parts i can
http://www.racetronix.biz/index.asp?...FromFeatured=1
