Generation IV External Engine - Headers running too hot , please help
PONTIAC SLP
02-20-2012, 06:53 PM
Hi , My friend installed his new LS3 engine and put into his 2007 Lumina SS , Well after installing we start up the motor and noticed the both sides headers are running too hot and the color of the headers changed to orange , After that we replaced the seals for injectors and intake and still running same , Car isn't missfiring and the idle is good .
I told my friend maybe you have bad knock sensors or timimg is retarded and has bad spark so what you guys think ?
Thanks in advance
gs462
02-20-2012, 07:16 PM
Glowing headers are usually a sign that the motor is too lean was this motor tuned??
PONTIAC SLP
02-20-2012, 07:19 PM
No yet he didn't tuned .
gs462
02-20-2012, 07:30 PM
I wouldnt run the car too much or drive it till he gets it tuned you may damage something.
mbaker3
02-20-2012, 07:36 PM
Could be too lean or too retarded timing. It might still be burning fuel in the exhaust.
02_CETA_ws6
02-20-2012, 08:49 PM
i just ran into this problem on an older 350, what type of manifolds are on it? that was the problem with ours, cheap headers=800 degree exhaust gas, swapped headers and went to 350 degrees, just something to check, i replaced manifold and gaskets and carb. before i figured it out.
Old Geezer
02-21-2012, 07:00 AM
Huh???
disc0monkey
02-21-2012, 09:38 AM
wheres the timing set at?
02_CETA_ws6
02-22-2012, 08:14 PM
Huh???
if your responding to my post....... sounds crazy but that was the problem.
Ballzee
03-13-2012, 11:00 PM
+1 here
2kblackgtp
03-22-2012, 10:50 PM
I'd go with too lean as well, get that thing tuned
redtan
03-23-2012, 07:13 AM
Did you put this LS3 engine with its own computer in the Lumina? Or did you just pop it in there with the stock Lumina computer?
