Hose length and Alternate regulator locations?
Old 02-21-2012, 07:07 PM
bayer-z28's Avatar
Default Hose length and Alternate regulator locations?
I'm looking for two things...
1: What length of hose to go from the fuel tank to the engine/fuel rails?
And
2: Are there any alternate aftermarket pressure regulator locations? I was thinking of hiding mine somewhere underneath around the driver's rear seat area. Obviously underneath. Trying to keep cost low and the possibility of a leak even lower. Trying to eliminate having to re-run BOTH supply AND return throughout the length of the car.
Old 02-22-2012, 07:13 PM
tunedup's Avatar
What exactly are you trying to accomplish?
Old 02-22-2012, 08:04 PM
bayer-z28's Avatar
Trying to install a regulator.
Old 02-23-2012, 06:29 PM
bayer-z28's Avatar
Anyone?
Old 02-23-2012, 06:38 PM
LS1TECH Sponsor
Lonnies Performance's Avatar
Mount the reguator where the pressure needs controlled.... at the engine.
Under the car is always a compromise.
Do it correctly the first time & save yourself some troubles.
Old 02-23-2012, 06:51 PM
bayer-z28's Avatar
^ Yeah, true.. Can I still use the stock supply line? This is gonna run $400 just in fuel line if I redo the supply and route a return in braided. Any ideas on that to keep the cost down? And what are the return pressures? I was told to use the same size for a return as the supply, figuring the pressures would be upwards of 60psi as well.
Old 02-24-2012, 07:16 PM
bayer-z28's Avatar
Anyone?? I figured these were fairly simple questions. Stock supply is fine for flow with a #8 return??
Old 02-24-2012, 08:25 PM
joecar's Avatar
Can you do the return in hard line instead of braided hose...?
Old 02-24-2012, 08:26 PM
bayer-z28's Avatar
^ Could I?? Good question.. Would save some money. Run a hard line most of the way and only end up doing maybe 10' of braided.
