Help me choose a cam 5.3 with a s480
Old 02-22-2012, 06:13 PM
sq_creations's Avatar
LS1Tech 10 Year
Default Help me choose a cam 5.3 with a s480
My old setup was a forged lq4 with a borg warner s480 turbo with the 1.32 96mm wheel exhaust and race cover compressor housing. It made 770whp with a Zo6 cam threw a powerglide and ptc 5500 stall. I ran 9.52@147. Long story short - I lost a lifter and damaged the cam. I also lost a rod bearing. Now I'm running a stock lm7 5.3 and want to pick a cam that will do good in this setup and eventual swap it over to the 6.0 when I get it back together. Also for the 6.0 I think I'll switch over to a ls3 head & intake when I get it back together vs the 317's I was running. The last thing I would like to mention is I'm running comp 918 springs so I was trying to keep the lift well under the .600 rating. I'm shooting for the 850~900whp range and hopefully 8.99's.
So the two I was thinking about were the:
Comp xr281hr 228/230 .571/.573 112 $349 - hotrodmag 4.8L twin 76mm = 1200 flywheel hp
or
speed inc tu1 225/225 .581/.581 113 $380 - http://www.ls1speed.com/article2/index.htm - 76mm 348ci = 851 wheel hp
Here are some picture of my setup.
Old 02-22-2012, 10:22 PM
831jd's Avatar
How will it spool with a 1.32 ar on the 5.3 doing same build im going with the tu1 cam....
Old 02-23-2012, 06:58 AM
Sarg's Avatar
Still debating on my cam for almost the exact set up...different intake but same turbo with l33 5.3 and 317 heads. The only "turbo" cams I saw from comp had .60x lift which is more than I want as I think the heads will be done at .550ish.
Old 02-23-2012, 10:20 AM
LS1Tech 10 Year
I'll have to get back to you on that. Haven't really gotten to beat on it yet.
Here is a link to the 6.0 Dyno Graph from last year.
Old 02-26-2012, 07:50 PM
ep142's Avatar
curious what cam you ended up going with
Old 02-29-2012, 06:25 AM
Sarg's Avatar
Wondering if some of the more "NA" split cams might not work better on the large turbo with a smaller motor. I was looking at an article last night by gm high tech where they took a 5.3 and tested it with 2 cams by comp and stock vs fast 102. Interesting findings. They can cams and intake both in NA trim as well as with the turbo.
Old 02-29-2012, 04:40 PM
LS1Tech 10 Year
I ordered the COMP CAMS PART NUMBER #54-428-11 - XR281HR
I'll let you guys know how it goes when I get it in.
Old 03-06-2012, 07:34 PM
T76s10's Avatar
How much does your datsun weigh without you? I love that little mother ******.
Old 08-06-2012, 10:36 AM
831jd's Avatar
any updates
Old 08-07-2012, 06:05 AM
Sarg's Avatar
I ended up grabbing the Lunati 277/283 cam after a good bit of discussion with LilJohn over on YB.
Quick Reply: Help me choose a cam 5.3 with a s480
