Oh no, knocking noise from drive train.
Drove car yesterday and a loud ticking noise started. It got really loud when throttle is applied. My air fuel meter was going crazy. It sounds like a loud sewing machine. It sounds like it is coming from the drivers side valve cover. Any ideas on what it might be. Just got car back from heads and cam install a couple of weeks ago.
Lets see, big cam,sewing machine noise, sounds normal to me, any SES lights yet? if you dont have tuning the first one you have will probably be p0300 random misfire, what do i win?
LS1Tech Co-Founder
Is it idling bad?
You might have a broken spring, it could be many things. I'd get it checked out.
If your oil pressure is going up and down at idle then it's a spun bearing but I doubt that's your problem.
I have tuning and the car was running fine. Oil pressure is fine. The ticking noise is WAY louder than the normal sewing machine sound. I plan to have it checked out soon. The car idiling fine. What ever it is, my air/fuel guage is going haywire.
I'd first check to see if all plugs are in tight. I'd then check the header bolts, and check and make sure no exhaust leaks are present. Those are the simplest solutions. Next, pull the valve covers. Check for bent pushrods, loose rockers, or broken valvesprings. I just went through this problem and it turned out to be a rocker arm bolthole was stripped, and the bolt had backed out. I had to insert a helicoil.
Whatever the case is, I would NOT drive it until you have inspected the valvesprings. It is highly possible it could cause extreme damage to pistons, and render the car not drivable. Is the car misfiring (flashing ses), or does it seem down on power?
Josh
Josh
had same problem bout 2 days after i got my z,turned out to b 4 bent pushrods,luckily no major damage need 2 get it checked asap,hit rev limiter and when i did it bent them them just like that,major power loss
