TSP/ PRC aftermarket LS3 heads and GT-11 cam installed
Old 02-25-2012, 06:49 PM
mongoose z28's Avatar
Default TSP/ PRC aftermarket LS3 heads and GT-11 cam installed
I recently had a few upgrades done to my SS and wanted to share the results with you guys. The parts that I had installed were
- LS3 conversion parts with LPE GT-11 cam
- PRC/TSP aftermarket cylinder heads with 68cc combustion chambers for stock compression.
-LSA head gaskets and ARP head stud kit.
-Yank 2800 stall converter with tranny cooler.
-91 Octane tune
- Most mods done in anticipation of a blower next year.
Previous mods to install were the usual bolt ons. It had Kooks 1 7/8" LT headers, Fastlane CAI, V-Max ported TB, GMS plug wires and a tune.
Car baselined very low for mods at 339RWHP and 365RWTQ. It was determined that the previous tune was off and showing knock. Numbers after the mods were 440RWHP and 406RWTQ. I was for sure expecting more especially on the torque side but the 91 octane tune and/or the new converter might have hurt the numbers. I have seen similar to better #'s with a ported stock casting on different cars with that cam but I'm pretty sure they had a 93 octane tune and no converter. The real test of these mods will be at the track this spring.
Car does run very strong with stock like driveability. In fact if not for the converter I think it would have drove no different than stock. Exhaust note did for sure get louder to say the least, LOL. There is a little bit of lope to know that a cam is there from a gear head listener but to the average person I dont think they would know. Now if I go WOT at any speed under 30MPH I get SEVERELY sideways. It also pulls very very hard up top. ALL in all I am very happy. I will try to post a dyno sheet but have been having trouble doing so.
Old 02-25-2012, 06:58 PM
Default dyno sheet
TSP/ PRC aftermarket LS3 heads and GT-11 cam installed-dyno-sheet.jpg
Old 02-25-2012, 07:58 PM
Tainted's Avatar
The tune could be better (obviously) and the converter will eat up some power. All in all I dont think you did to bad. Youve got good avg power all the way across.
What are those cam specs?
Old 02-25-2012, 08:18 PM
DietCoke's Avatar
Should have pulled it another 800rpm. That motor wasnt near done.
Old 02-25-2012, 10:45 PM
blackonblacksls's Avatar
what makes you think the tune could be better?
Old 02-26-2012, 01:35 AM
I assume he means if I was able to use 93 octane with a 93 octane tune because my AFR looked good and my tuner is awesome.
Specs for the LPE GT-11 cam are 215/231 .631"/.644" 118
Old 02-26-2012, 07:43 AM
davidws6's Avatar
Good results for that size of cam + like Tainted said, the conv. will eat some.
+ "SEVERELY sideways" in that 5th gen, that's damn good !
Old 02-26-2012, 09:57 AM
Tainted's Avatar
Just the octane tune. Running 93 would clearly yeild more power.
But that cam is fairly small although its got some lift to it. I think all in all it did well. Easily be over 450whp with higher octane and stock stall.
Old 02-28-2012, 04:02 PM
HoP
HoP's Avatar
Post the dyno graph in RPM not MPH please. You'll be surprised with the results lol.
Old 02-28-2012, 04:56 PM
litle88's Avatar
Are you the vader SS L99 on Camaro5.com?
IMHO I'd like to know about the dip in hp and looks like Tq at the end of your pull. Can you post the graph with the rpms like stated above? But also try to include the AFR as well. Like Diet said the cam has a Lil more in it. But just my .02
Old 02-28-2012, 06:00 PM
LS1Tech Premium Sponsor
Jason 98 TA's Avatar
Id like to see it in rpm so we can see what rpm it was pulled to.
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old 02-28-2012, 07:09 PM
Yes i'm the Vader SS L99 on Camaro5. Looks like it was pulled to about 6600 looking at my paper dyno sheet. I'll see if I can get that one on here.
Old 02-28-2012, 07:27 PM
litle88's Avatar
Well I can't calculate accurately but if you have a stock gear 3.27 and he pulled in let's say a 4th gear which is a 1.152 or a 5th gear which is a .852 And you took it to 132? Someone will do the math lol
http://www.wallaceracing.com/Calculators.htm
Old 02-28-2012, 07:28 PM
litle88's Avatar
Sorry at work
Old 02-28-2012, 07:48 PM
Default AFR, RPM dyno sheet
dyno sheet.pdf
Old 02-29-2012, 01:51 AM
NemeSS's Avatar
Im a big fan of the gt11. Sounds like a very strong combo
Old 02-29-2012, 02:15 AM
bww3588's Avatar
I think about 8 degrees more duration on the intake side would have given you a good bit more power. With the large lift and relatively low duration your air velocity has got to be pretty high to feed the cylinder. I think this cam would really shine on a l76 or any 4 inch bore motor.
Old 02-29-2012, 05:30 PM
gtotoocool1's Avatar
i think the numbers look good,especially since it looks like that cam is spec'd for a blower application.plus you don't have the most dyno friendly drivetrain either.don't sweat the dyno #s,see what it does at the track!
Old 03-01-2012, 07:17 AM
venom ws7's Avatar
Mild cam , stock compression , 91octane and stalled I say those are good numbers..
Ported Fast 102intake & TB will make another 15-25rwhp and similer tq. (yes I know they're expensive)
Old 03-01-2012, 01:06 PM
Really expensive considering I will be adding a Whipple next year. LOL
Thanks for the positive feedback everyone. Makes me feel a little better about droping the extra coin on the heads.
Quick Reply: TSP/ PRC aftermarket LS3 heads and GT-11 cam installed
