WS6 Next Upgrade advice
I live in California and im Looking for advice to point me in the right direction on what to buy and install next on my 01 trans but still be able to pass smog emmisions, I'm looking for the best, so far:
Slp loudmouth exhaust
stainless airlid with k&n filter
vogtland springs
New Continental extreme contact tires
vogtland springs
ya unless you have friends longtubes wont pass. there are cam's that have been tuned and can pass smog, talk to Pat G to get a spec'd cam. otherwise, start the suspension upgrades so you can actually use the power you currently have instead of spinning them away with those tires.
i was hoping someone would say cam lol tho is the cam guarenteed pass CA emissions or is it a maybe? I want the best and most aggressive but still be legit, i know i can't go TREX style but whats the closest. The reason is because the pigs been trying to catch me riding dirty, but I got beat by a Evo last week, can't let that **** happen again, what about injectors? Ignition **** even spray? How dangerous is a dry shot into the airlid?
There is so many ways to get a car to pass emissions with something "illegal" such as a big cam. But the 224r should pass easy. It won't give you a big gain like the Trex cam but probably another 35 rwhp with a good tune. Get it with a tall enough lsa and no one will ever know its there.
224/224 114lsa is the unwritten size/overlap limit(-4*) for California, you can go with a different duration on the lobes but you need to keep the overlap to -4* or more(-6*, -8*, etc..). I'd also have your factory heads ported and milled or get a set of AFR 205s or 210s(has CARB EO#).
Nope! They'll just extract a few more ponies I'd only worry about a cam and headers effecting emissions, but as others have stated... the 224R cam is perfectly legal for emissions. Sounds pretty good even on a 114 LSA. Good luck with your car!
damage? like $ or real damage?
a 100 shot and someone that halfway knows how to use it wont hurt a thing. I've slapped a 100 dry shot hidden on a stock 98z28 before just to outrun someone. Not the right way, but it can be done
you can find used kits and parts and spend like $250 on a wet kit all the time if you stay on CL. Dry kits even cheaper.
