Trans Am Fog Lights
Ok, I found the lighting FAQ but most links are extremely old and don't work.
Also found these: http://www.rallylights.com/detail.aspx?ID=132
Hella 90mm fog lights.
And the writeup: https://ls1tech.com/forums/appearanc...ll-w-pics.html
Why is this guy messing with relays, etc? Can't they just hook up to the factory harness?
I went aftermarket on my GP. I'd imagine the same ones I have would fit your T/A just fine since im 99% sure it's the exact same fog and bracket. All I had to do to mounts the aftermarket was drill two holes in the stock bracket. They EASILY overpower the stock headlights with Philips X-treme bulbs. The fogs have the no name brand halogens that comes in the kit.
Here's what I have. I never bothered hooking the halos up. I got them for the light output.
http://automatcentral.com/grandprix-...ing-lamps.html
Post a pic of your stock bracket/housing and I can tell you if they mount up the same or not.
I'll get you a couple pix later. PB is blocked at school.
Copy & Paste Moderator
I polished the ones on my '98... they were incredibly foggy/rock chipped. Hit them with the Mother's Headlight Restoration kit that I'd just used on my WJ's headlights and they cleaned right up. Looked as good as new sans a few micro dip's in the plastic that didn't sand out fully.
