GMMG + Factory CME?
GMMG + Factory CME?
Long time lurker, first time poster...
How easy/hard is it to mate up a GMMG exhaust to my factory center mount exhaust tips? Do I need to get some 2.5" band clamps to attach them, and am I gonna have to do any careful measuring and cutting to get it to fit right? This is gonna be going on my 2002 SS, and it will be mated to my Kooks stainless LTs + catted-y. Thanks for the help.
Steve
Steve
Geez, I just noticed the bar that was welded in right behind the tips...I wonder if that is there for extra bracing so the tips don't get ripped apart or what. That would probably be a big pain for me to have done around here...not too sure who all can weld stainless that I could trust to work on my car.
Steve
Steve
I've got that setup on my car. I don't have any welding done behind the tips like the picture shows and I have had NO problems what so ever. Its been on the car for over a year now. It is an awesome setup if I do say so myself
Awesome man...that's what I wanted to hear. Did you have to do any bending of any sort? Also, how did you attach the tips to the GMMG outlets...band clamps? U-bolt clamps? Just tryin to figure out how this is all gonna work out before I go digging myself a grave.
No bending at all and they are attached with U-Bolt clamps. No digging a grave at all. It sounds so good and WOW does it ever add to the Torque. I don't know why, maybe the extra bend or something but I'm over 350 TQ with just a TSP lid, Maf ends, S2, and the GMMG with the CME.
They can be a pain in the butt. For me the cme did not just slide onto the gmmg exhaust. But This is what I did at the end and worked great. Cut the elbows of the stock cme and remove the old exhaust. You may have to hack it up to get the old slp exhaust removed.
Buy two pre bent 90deg pipes from slp. I think they were 2.5" in diam. and are mandrel bent. They are long which makes it easy for the next steps.
Take the car down to a muffler shop. I already had my gmmg exhaust on, just without the tips. The muffer shop cuts the new elbows, expand the ends to fit and my problems were solved. Used band clamp at the tips and U-clamp at the gmmg part. Heres some pics.
The CME tips give the GMMG just barely a little deeper sound. This was comparing it to my CME setup and a GMMG on a D/D setup. LS1sounds.com has wavs of my setup there or you can go to my site and listen to them.
The CME tips do seem to add deepness to the exhaust note. My Corsa is deeper and rumbles more than other Corsa's i've heard in person and online. My Corsa muffler was not too hard to add in place of the DD. It's just the fact the Corsa muffler is 3" inlet @ 3" outlets so I had to use 3" to 2.5" reducers. Flows pretty damn well, only picked up 4rwhp @ 5rwtq with my QTEC in I pipe.
I have the gmmg on my car and i just bought the oval tips with it and it only took me about 15-20 minutes to install it. I did have a lift and power tools though. You make one cut on the old exhaust and it will come right out. Then the new exhast was precut and slid right into place.
Since adding the new exhaust ive had trans ams and camaros stop me and ask what kind it was, sounds awesome.
my ? to you is why did you cut it....because there wasnt enough room to remove the tips due to the skirt on the rear is my gues...it woulda beeen much easier to remove the skirts dont ya think?
ive learned that there is nothing to really worry about...ill go into place, sound deeper/quieter, not by a whole lot tho, and possibly *** slight backpressure, nothing dramatic tho. jsut my $.02
