o2 sensors with extenders or corvette o2 sensors?
I'm going to be installing LTs in my 2000 Z28.
I've heard that the Corvette o2 sensors are longer and don't need extenders. If that's the case, would that be a better option for my set up rather than buying the o2 and extenders?
Thanks,
Joel
Thanks,
Joel
Thanks for the info.
I just called a local auto parts store and I was quoted the following for o2 sensors.
2000 Z28 Camaro
$44.99 and $41
2000 Corvette.
$34 and $ 47
Needless to say, I was expecting the Corvette o2 sensors to cost more.
Perhaps I didn't ask for the right ones? I'm also worried about the Corvette o2's possibly throwing codes or causing other problems.
Can you guys please suggest some good bang-for-your-buck o2 sensors?
Thanks,
Joel
2000 Z28 Camaro
$44.99 and $41
2000 Corvette.
$34 and $ 47
Thanks,
Joel
$34.30 shipped on Amazon for Bosh 13111s
http://www.amazon.com/gp/product/B00...F8&me=&seller=
It seems to good to be true, are they right ones? If so, I'm getting myself a pair ASAP.
Thanks,
Joel
Thanks,
Joel
Thanks,
Joel
Thanks,
Joel
Thread revival... so i've been searching for a good hour and came across this thread having trouble with long tubes and my front o2 sensors... so the front corvette sensor of the same year works plug and play?
The free and easy way to do this is to just plug your original front o2's into your rear sockets and repin your PCM so your rear sockets read the front o2's. It's free, you don't have to use 20ft extra of wire, and you're re-using nice factory o2's
And the rear(after cat) 1999 corvette sensor will plug and run properly in my front on my 1999 trans am.. know I sound like a retard but I want to be 100% sure before I buy 2 and waste money:p
