GARAGE SALE ......huge list of parts
Category: Accessories
Price: $123456
Part Fits: 93-02 Chevrolet Camaro
Location (State): MI
Item Condition: Used
LS Engine?: Fits LS Engine
****shipping/paypal based on zip code not included*****
email me or pm superdavegl@aol.com
ebony CAMARO SS floor mats OEM PERFECT NEW IN BAG 100
ebony throphy Camaro SS mat 100 brand new 100
LT1 Fuel lines hard 95 and plastic 25
RK SPORTS hatch spoiler for camaro 93-02 sold
98-02 COWL HOOD sale pending sold
brand new condition 2002 camaro hood sebring silver removed in 02 sold
door exterior seals. glass to paint seals dr and pass 30
antenna. 10
90mm FAST throttle body plate not perfect but works fine sold
90mm sheet metal elbow shipped sold
like new ls6 inject 1 hour time 100
Chassis heat shields 10ea
Door hinges 20ea
Black roof bar "targa" sold
fog lights parts misc price
ls1 sheet metal valve covers mocked only 115 shipped sold
head light bar holds lights 30
Front impact metal support custom milledfor racing 98-02 sold
Steering u-joint plastic covers 10ea
Driver window parts misc price
T-top conversion parts misc price
Convertible pump low miles 200
Convertible top arms 200 each
Other various convertible pieces
Windshield washer res. new 35
Windshield washer pump new 12
pass door not great sold
whitedriver and pass door only 5k miles 300 each
steering column sold
under dash plastic insulator above feet area 10
20mm rear sway bar 30
radiator air deflectors 10
air dam under car rk sports 25
targa band for t top conversion sold
driver rear 1/4 for rust repair 50
tan pass rear 1/4 plastic tire cover area small issue 5
rear berger panel 65
t top receivers 12 ea
wiper motor assembly 50
lt1 evap can 10
driver 1/4 evap vent 10
evap plastic lines 10
rs body body clips 6 ea
cruise control control and cables 50
Interior Pieces
Spare tire wrench 8
Air bag modules 25ea
all seat belts in brand new condition 20 miles on them $200
used coupe seat belt 100
Seat belts for convertible 130
GM stereo amps 25 ea
air bags 93-02 35
tan cargo cover 20
t top left or right 65 one missing inside plastic use old plastic
lots of body electrical ends
hvac controllers 25
speaker grills 5
ls1 front fuse box plastic holder, brand new condition. 25
2002 ls1 cluster very low miles like new 150
cluster 0-120 mph v6 from 1999 85
cluster 0-150 mph v8 from 1997 100
Engine:
ls1 engine part
upper air box removed when new 50
ls1/lt1heater core removed when new 40
lq4 suv starter new sold
lq4 used starter 50 sold
lq4 intake,inject, rails sold
ls1 y pipe pipe like brand new 125
ls1 fuel rails from stock ls6 intake sold
ls1 fuel pump used 100 miles like new oem 90
ls1 rocker arms used 75
ls6 water pump used 1 hour like new 145 oem
Fueling:
Gas tank straps sum rust 10
Fuel rails lt1 35
Fuel rail to long fuel lines lt1 30
Fuel line and return from gas tank to lower fuel line connection (longest lines on car) 100
v6 fuel pump used 25
Braking:
LT1 calipers 25 have see whats left
LT1 front and rear rotors need cut sold
V6 drive by wire pedals 1999 50
V6 brake pedal single 1999 25
Exhaust:
LT1 Exhaust Manifolds need bolt removed sold
ls1 rear brake swap 1000 miles from new on parts (no Ebrake handle in pic) sold
(cailpers clearanced for 15" rim) near new condition
Wheels/Tires: sold
Drive train and Misc.:
Most nuts bolts for whole car
clutch, flywheel, pressure plate, clutch lt1 stock used need cut 100
sway bar mounts upper 10
sway bar lower half's 10
steering u joint plastic covers 12
lowering spring set sold
rear spring isolator 20ea
stock lca 20ea
many misc lug nuts from 93-02
body elect ends mics,cut so you can repair yours
driver glass 25
lt1 crank hub 30
pass glass 25
30mm front sway bar
gray cargo cover one pivot gone still very nice cover 25
lt1 heads will need repair 100 pr
lt1 intake 40 need cleaned
lt1 injectors 80 set 8
rad over flow tank brand new cond 50
throttle body cable plastic cover 15
lt1 coil 15
lt1 head coolant tubing 25
lt1 brand new oil pan 50
lt1 valve covers 30
lt1 alt 70
2002 z28 pass air bags with est 100 miles 70
steering column support 10
I have alot of the smaller parts just ask.
