Are coated turbo headers less prone to cracking?
Ive got my hotparts coated in jethot 2000 and do not have my turbo braced. Do ceramic coatings or any other kinds strengthen the metal at all?
The passenger side header points towards the rear of the car, then the crossover goes under the oil pan by the kmember where theres a flex joint then comes up under neath to the dirver side header..
Welding all the header tubes together with a couple small pieces will strengthen up the header a lot. You could put them underneath and never see them. My friends Honda header was cracking pretty bad that he bought, I welded a couple braces in and it tied the entire structure together. If your header is not in the car, put it in a vise, clamp it by the flange and hit the other end with a rubber hammer. If there is a lot of vibration/resonance then you could have a problem. This header resonated like crazy. After a couple small braces it was solid as a rock. And you cant see them from on top the car.
[IMG][/IMG]
[IMG][/IMG]
Interesting for sure...my driver side header looks pretty beefy but i will post more pics of it when i get to my work computer..ive also heard ppl say bang the turbo lightly and see if it vibrates much
