problem with transdapt 1" back kit
Old 03-08-2012, 07:48 PM
jcuadra's Avatar
Default problem with transdapt 1" back kit
im having trouble monting this kit to my block. the mounting plates go on fine but the bolts that are suppose to hole the second piece (mount) are hitting the block and wont screw all the way in.
can someone post pics please
any and all advice is appreciated. thanks in advance
Old 03-08-2012, 08:01 PM
89sierra's Avatar
guys have posted this problem before you need shorter bolts, cut your bolts down or run washers in between
Old 03-09-2012, 09:45 PM
jcuadra's Avatar
Thanks.. ill just make a trip to the hardware store and get some shorter bolts
Old 03-09-2012, 10:01 PM
jfg455's Avatar
I had to trim the front corners on the two sets I used so they would sit flat on the block.
Old 03-10-2012, 03:50 AM
85GPLEf41's Avatar
are these the trans dapt 4595 mounts?
Old 03-10-2012, 05:21 PM
jcuadra's Avatar
I don't have the part # with me right now but I'm pretty sure it is the 4595 kit
Old 03-10-2012, 08:11 PM
Stoney667's Avatar
Same deal here I have the 4595's as well. Had to notch the corner and going to have to get shorter bolts or cut them.
Old 03-11-2012, 01:17 PM
cyipher's Avatar
x3 on trimming bolts and corners
Quick Reply: problem with transdapt 1" back kit
