Borg Warner S368 Turbo in good condition
Category: Engine - Power Adders
Price: $450
Location (State): FL
Item Condition: Used
Engine: LS1/LS6
LS Engine?: Fits LS Engine
I bought the above turbo about 8 months ago IN PERSON. I know ZERO about turbos so before I bought it I asked the seller if I could take it to Superior Turbo and Injection in Detroit (where he purchased it) to get a quote since he said he thought it might need a rebuild. I brought it to them and they said it did NOT need a rebuild. I purchased the turbo for $450 and have not mounted or run it since. It has sat sealed up in a tote with tape over the inlets/outlets. My build was on hold but has now resumed and my desires have increased quite a bit....I want to have enough turbo to run LOW 9's or possibly high 8's.....and this turbo will not do that.
Sorry that I cannot answer a lot of questions, turbo knowledge is NOT my strong point.
Below is the seller's original post on here (same as link above).
For sale is a Borg Warner S368 Used Turbo i had on my camaro for about a season. Decided i wanted to go back to a nice N/A setup.
The turbo Worked great and pulled hard at 12lbs!
On 10lbs with this turbo i made 540rwhp
on 12lbs it made a lot more!
The Turbo is in good working order but have some shaft play. I would rebuild it. I pulled it off in good working order. No smoke came from it.
I bought this brand new from Superior Turbo and injection from Detroit. It goes for about $850 new
The exhaust housing is a .88 A/R with a T4 Flange
If you have a turbo that will be able to fill my ET goals and you want to go smaller, I can add cash. Price is $450 plus exact shipping and insurance if requested. Can be seen or picked-up in Tampa Florida.
