Gen 5 Camaro Internal Engine Tech - Help Please 2010 Camaro
Kevinusmc
03-12-2012, 10:01 AM
I am new to the world of working on cars I was wondering if someone could help me. I installed Borla Atak Aggressive Cat-Back Exhaust System. and K&N Cold Air intake. The car was not as loud or as powerful as I wanted it to be so I ordered JBA Mid-Pipe for 2010 CAMARO WO/CATS, Then one of my friends told me to get new cam, and valve springs. So I ordered MTI Racing Stage 3 LS3 Camshaft :: 2010-2012 Camaro SS, and Livernois Motorsports LS-Series Dual Valve Springs.
My question is with the new cam and valve springs do I need to change the Push Rods and the Timing Chain? If so can anyone please tell me which pushrods and timing chain would be good.
Thank You
Kevin
sweetC5
03-12-2012, 02:42 PM
The timming chain could be resused if you have low miles, pushrods need to be checked for lenght and should be replaced with a cam that agressive. Talk to the vendor that sold the cam to you about the pushrods.
That big ass cam is gonna be choked up without long tube headers... I would at lest get some budget headers if you dont have much cash. Personally I think you went to big with the cam, do your home work before you spend a bunch of money and have a slow car! That cam will run strong on the top end, but you need headers and a tune to go with it.
Kevinusmc
03-13-2012, 03:40 PM
I had the borla XR-1 long tube headers in mind I have them in my shopping cart haven't checked out yet. Would those be good enough?
Ok so I purchased the Mti stage 3 racing cam, stainless power 1-7/8 long tube headers w/o cats, livernois dual valve spring patriot 8401 kit and GM 3 bolt cam sprocket. Talked to phastek performance and that's everything they said I need for everything to be good.
Gunslinger09
03-15-2012, 10:51 AM
Yep that should do it parts wise. Do you have someone to dyno tune it? You will need a tune with that cam for the car to run right.
Kevinusmc
03-15-2012, 02:17 PM
Yea I have a shop here in NC that is gonna install the parts and do the tune for me.
sweetC5
03-15-2012, 02:55 PM
Sounds good man, good luck... it should be a beast!
No Hope
03-17-2012, 02:30 AM
a little advise, do your research before you start buying parts. Make a plan with a budget and talk to a couple of different shops about your plan and then buy your parts.
Next comes suspension mods and drag radials.
Good luck.
rockit_z28
03-17-2012, 06:51 AM
Good luck! Should be a great car. As mentioned above, you will need some suspension work to help get that power to the ground especially on a stick car. Wheel hop is not your friend and these cars are prone to breaking parts with wheel hop.
Kevinusmc
03-18-2012, 07:07 PM
Thanks everyone for your inputs. So with wheel hop I was researching and came across some ideas if I got a swaybar kit with bushings front (sb016) and rear (sb017) and a lowering spring kit set of 4 1.4" front and 1" rear. I was wondering if anyone new how much that would help out with wheel hop and If that would be good enough when I got a supercharger for my car.
Was also looking into getting hotchkis 20104 chassis max brace and front and back strut bars.
I also see BMR performance has level 1,2 and 3 handling performance packages not sure If it would be better to go with one of those or go with the parts I was looking at in the earlier post.
someday
03-18-2012, 09:10 PM
didn't MTI go outta business a few yrs ago? is there a new MTI? what r the specs on that cam? it may not work with a SC down the road...
Kevinusmc
03-18-2012, 09:38 PM
Camshaft specs 231/243 .617/.624
someday
03-20-2012, 09:14 PM
what LSA? u need at least a 114 to work well with a SC'er...
No Hope
03-24-2012, 12:35 AM
If your getting wheel hop you need a set of trailing arms.
BMR is the best bang for the buck suspension company out there.
A set will run you $150 for plastic bushings and $250 for arms with bearings.
Kevinusmc
03-25-2012, 09:51 PM
The lsa is 115 +2 and for wheel hop I purchased a PFADT stage 3 performance kit, Pfadt sway bar end links, and comp cans gm ls series retrofit trunnion kit.
Gunslinger09
03-28-2012, 05:24 AM
Sounds good man. Now get some dyno numbers and track times.
sweetC5
03-28-2012, 07:44 AM
That max brace is a good idea, that will stiffen the hole car up. Keep us updated on the numbers, mine is gong on the dyno next week.
Kevinusmc
04-24-2012, 06:14 PM
My car is at rpm Motorsports in Garner, NC getting my camshaft, suspension, headers, cam sprocket, valve springs, push Rods, and Procharger installed and tuned and dyno will get my car back on Friday morning can't wait.
Gunslinger09
04-25-2012, 09:46 AM
Dang.
You are getting all done at once huh? Good luck and enjoy the car.
Kevinusmc
04-25-2012, 12:07 PM
Yea man I figure while I still have my money I made while in Afghanistan get it all done now b4 I spend it on stupid stuff and not have it for my car.
Gunslinger09
04-25-2012, 12:15 PM
I remember many moons ago coming home with a wad of combat pay burning a hole in my pocket. Enjoy it man.
Kevinusmc
04-26-2012, 11:41 AM
RPM just called the camaro is going on the dyno later on today will post some numbers later :-)
Gunslinger09
04-26-2012, 12:49 PM
I'm going to guess 600+.
Martin718
04-26-2012, 01:01 PM
How much boost? Any meth?
Kevinusmc
04-26-2012, 09:01 PM
The last pull was 725rwhp and 610rwtq with 9lbs of boost no meth yet. The guys at rpm said I can get higher but I have stock bottom end and they don't want anything to happen.
Gunslinger09
04-26-2012, 11:53 PM
That thing will be a blast to drive! Now you will need to own stock in a tire company.
Martin718
04-27-2012, 09:15 AM
I've NEVER seen a 5th gen make that kind of power on a 9psi pro charger setup especially with no meth. I find it almost hard to believe
We had a Dyno day not long ago with over 10 5th gens all with chargers either Maggie, whipple, or pro charger. None made over 660rwhp without meth
Kevinusmc
04-27-2012, 06:50 PM
I got the dyno print out is there a way to put it on this forum
Gunslinger09
04-28-2012, 09:13 AM
Use the go advanced button to reply to the thread. there is an insert image Icon on the menu bar above the text field.
Kevinusmc
04-28-2012, 10:38 AM
heres the dyno sheet
Gunslinger09
04-29-2012, 08:07 AM
That sure looks like 725 horse to me on that Dyno sheet.
Kevinusmc
04-29-2012, 03:05 PM
Yea it is lol had no reason to lie about it haha.
Johnnystock
05-03-2012, 01:19 PM
hp is still climbing..
Kevinusmc
05-03-2012, 08:00 PM
Not stopping till I'm over 1000 :)
someday
05-03-2012, 09:26 PM
yeah, with that big cam, its still making power... notice the tq didn't drop off, so the hp would keep going up if u took it to 7K...
Martin718
05-04-2012, 09:36 PM
You've got a long way to go and a lot of changes to make to get TO 1,000
Kevinusmc
05-05-2012, 06:06 PM
Yea I understand it's not gonna happen over night but all I got is time and I will get there
Martin718
05-06-2012, 08:38 AM
It's an expensive endeavor trust me im in the midst of it now. Long and short you'll have more in the drivetrain than you did buying the car!
Kevinusmc
05-17-2012, 07:44 PM
under the hood so far
354594
silver2010
05-19-2012, 07:10 PM
I have a procharger F1R running at 15lb. of boost and made 933 on the dyno yesterday on race gas getting tuned to trailer it to the superchevy show.
Ran a 10.57 off the bat. at 138.83
I advise you to get the bmr chassis brace to help the stiffness. I say this because my car with a combo of pfadt and bmr components is keeping the car straight thru the qtr.
Ken
silver2010
05-19-2012, 07:14 PM
Kevin check this out. My motor.
Kevinusmc
05-20-2012, 05:24 AM
That is nasty bro looks amazing. How long has it taken you to get to that power. I have a question for you hopefully you can tell me I'm new to the working on my car thing the shop that put it on the dyno Said I can get more power but I have a stock bottom end what exactly do I have to upgrade so I don't have a stock bottom end? I appreciate if you could steer me in the right direction.
Gunslinger09
05-21-2012, 05:49 PM
You would need at a minimum forged pistons, Hbeam rods, and forged stroker crank. The stroker gets you more ci which all by itself will give you more power. The forged rotating assembly will allow you to force even more air into the motor and make still even more power. I would recommend upgrading your drive line to handle that power level first though.
silver2010
06-19-2012, 04:16 PM
Ken
Well on that day at the superchevy show we turned up the tune for 112 racegas and blew the stock rearend out.
If you have any intentions of running low 10's or high 9's on this heavy car then get a 9 in. rear like the gforce I have ordered and a strange gearset.
At the same time I'm going with a 4l80e trans built by rpm and the controller made by tci.
I also have a one piece drivshaft coming so maybe I got all the weak links out!
On you trying to get that much hp out of a stock shortblock, the life of it will be short.
Ken
silver2010
06-19-2012, 04:22 PM
^This plus a set of mast heads. And get rid of the serpintine belt.Get a cog setup, they don't slip.
Gunslinger09
06-21-2012, 09:29 AM
I'd love to have a 9 inch IRS set up but $7 Grand OTD is too rich for my blood. I will stick with a goal of around 600 HP since the stock center section is supposed to be good out to about 650HP.
Martin718
06-21-2012, 10:52 AM
I had 32,xxx miles at 712rwhp on completely stock driveline just clutch. Only had one stock axle break and that was when I let a buddy drive my car and he had traction control on and it wheel hopped. Slp on eBay sells sets of axles for 90$. Easy 30min swap for a budget deal to buy some time.
Gunslinger09
06-21-2012, 05:54 PM
That's good to hear. That means my plan for the steel 4:11 gears and 1000 HP rated axles will work.
Martin718
06-21-2012, 07:50 PM
I've heard the stock center will hold up to a good 1,000hp
I'm ordering the g force though my goal is 13xxrwhp in the coming weeks
Gunslinger09
06-22-2012, 06:18 AM
My goal is to have the power and be able to hook up well enough to run 11.5xx. I want to be able to easily use pump gas and be able to run just a hair slower than where I would need a cage. Quick street car all the way for me.
Martin718
06-22-2012, 07:05 AM
Mine is and will remain a street car daily driver.
Mine ran 11.5-11.6 as it was stock rear, factory 20s ect so you shouldn't have a problem obtaining that goal
