easiest way to pull motor and tranny out a silverado?
Old 03-14-2012, 06:05 PM
9Green-Z8's Avatar
Default easiest way to pull motor and tranny out a silverado?
hey guys well like my title says do yall know the quickest and easiest way to pull the engine and tranny out of a 00 silverado? any help will be appreciated
Old 03-14-2012, 06:27 PM
04Vguy's Avatar
dynamite
Old 03-14-2012, 06:44 PM
EL T1's Avatar
Serious?
Old 03-14-2012, 06:49 PM
98_1LE's Avatar
http://www.youtube.com/watch?feature...dhGFCcHM#t=13s
Old 03-14-2012, 07:50 PM
04Vguy's Avatar
No not serious sorry but another funny note
http://www.youtube.com/watch?v=FctRS...e_gdata_player
Old 03-14-2012, 07:53 PM
04Vguy's Avatar
Damn just realized that was a double post. Oops
Old 03-14-2012, 07:54 PM
stevensLS1's Avatar
Originally Posted by EL T1
Serious?
+1
No offense man but I'd just take the hood off ( probably don't even need to go this far) and pull it from the top. Truck has plenty of space unlike the 4th gen cars.
Old 03-14-2012, 08:30 PM
04Vguy's Avatar
+1^ A lot easier from the top in the trucks.
Old 03-14-2012, 09:04 PM
work in progress's Avatar
I think its easier pulling them separate. If you do, turn the motor 45* and it will pull out without any problems. If you pull them together its best to put the truck on jackstands so you can drop the tail of the trans down . Then crank it up a little, pull a little. Keep repeating until the tail clears.
Old 03-14-2012, 09:30 PM
v8sten's Avatar
a view from the other camera
http://www.ebaumsworld.com/video/wat...cRFqcvZti5H.01
Old 03-15-2012, 04:28 PM
LS1 pwrd NOVA's Avatar
Whole lot easier if the front clip is removed. With air tools it's quick.
Old 09-17-2014, 03:49 PM
RobMinhas's Avatar
Sorry to bump a two year old thread but I'm pulling a spare 5.3 at the junkyard this weekend(just the engine) and was hoping for some help.
From my reading it seems liek the best way is to make room in the front(removing front clip + rad), removing the hood, removing the exhaust from the manifolds then pulling it out from the top.
I've also read that unbolting the trans crossmember and letting the engine + trans "slump" down makes it easier to get to the bell housing bolts. I've also read removing the intake can help but that was on an Fbody forum.
The general plan is to remove the hood, unbolt the exhaust from the header, remove the rad and any other stuff in the front that might get in the way. Remove the wiring harness from the PCM, undo any grounds or mounted parts of the harness as well as any parts of the harness that go to the transmission, hook up some chains to an A frame hoist and mount the engine. Remove motor mounts/unbolt motor mounts, whichever is easier, drop the trans down by unbolting the cross member, removing the starter and bell housing bolts and then pulling the sucker out.
Any flaws in that plan? Anything I should do differently? Or anything I'm missing?
Old 09-17-2014, 07:27 PM
5w20's Avatar
Removing the intake lets you have easy access to the top transmission bolts. Remove radiator, accessories, and water pump and it slides out real easily.
Old 09-17-2014, 10:07 PM
RobMinhas's Avatar
The intake will be removed for an LS1 one most likely so I don't mind pulling it off, thanks for the info, hopefully it'll make the removal go by faster.
Old 09-18-2014, 11:31 AM
In-Zane Moderator
ZONES89RS's Avatar
A motor hoist.
Old 09-18-2014, 11:33 AM
LLave's Avatar
Rent a gas powered chop saw, cut away anything that doesn't look like motor. You should have it out in a giffy.
Old 09-18-2014, 06:31 PM
TXsilverado's Avatar
you guys make this too hard lol.
1) remove bolts from manifolds (against the heads) and let the exhaust hang.
2)remove starter
3)reach in with extension and squiggler and remove converter bolts
4) remove trans crossmember
5) let trans hang down and reach in with a long extension to remove all trans bolts. slide the transmission out to the side.
5)remove AC compressor and set to side (leave lines connected)
6)remove power steering bracket and set to side(leave lines connected)
7)unplug all wiring harness connections and lay the harness on the windshield. 8 bolts to the motor mounts and pick it up with a hoist and slowly turn the engine 90* inside of the enigne bay to avoid contact between the crank pulley and radiator.
dont remove the hood, dont remove the fenders, dont remove the radiator/core support, dont remove the intake/injectors/etc....too much ****. you have to have MASSIVE *** jack stands to get the engine and trans out together on a 00 silverado. even then, i'm not sure. i tried and it didnt work. once you do it a time or 2 you can remove and reinstall a trans/engine in about 6-7 hours.
look at the hood mount on an early style silverado. you can remove 1 bolt and stand the hood straight up without removing it.
The following users liked this post:
Dustin Cash (03-26-2020)
Old 09-19-2014, 06:14 AM
NastyTBSS's Avatar
2)remove starter
You made it way to hard...
1. Just remove the motor mount bolts.
2. Remove Trans mount
3. Hook chain to the heads
4. Hook other end of the chain to a stout tree
5. Reverse as fast as your tornado powered silverado will go
6. Sit in lawn chair and enjoy a cold beer
Quick Reply: easiest way to pull motor and tranny out a silverado?
