What valve spring to run? Under a budget
Wondering what spring to run? Found these two here... Lunati or Comp cams both are dual springs.
http://www.ebay.com/itm/COMP-CAMS-GM...#ht_2258wt_947
or
http://www.atlanticspeed.com/product...ory=48#details
Running LS3 heads with LS3 intake valves and i want a .615ish lift cam
Thanks
or
Thanks
I just rebuilt my stock heads. Had them cleaned and got a valve job. I went super budget and got ls6 beehives new for about $60 so I can reuse my stock retainers. They are good for .580 lift which leaves plenty of moderate cams to choose from. Am I going to regret not going with a better set of springs?
LS6 springs are not suitable for aftermarket cam lobes. They are designed for stock cam lobes. And 918s are now good to .625 lift but max lift is only one part of the equation. Just because your cam is under 625 lift does not mean a single spring will work with your application.
http://www.racingsprings.com/Store/P...?ProductID=205
I used PAC 1518s in my Z06 ... rest of the valve train is all stock except for some custom Manton pushrods and Trunnion Kit.
"High performance LS1 spring that features additional nitriding processing for increased durability for high lift applications up to 0.650 lift."
http://www.racingsprings.com/Store/P...?ProductID=220
LS6 springs are only good to .570 lift. But Lingenfelter has their LS9 springs that are good to .580 and they are only $70 http://www.lingenfelter.com/mm5/merc...Store_Code=LPE
http://www.lingenfelter.com/mm5/merc...egory_Code=C31
PAC says 1215s are good to only 0.600" lift.
typo on my part the 1518s are 188.00 on that site.
