What valve spring to run? Under a budget
Old Mar 16, 2012 | 03:39 PM
Fast 95 Z28's Avatar
Default What valve spring to run? Under a budget
Wondering what spring to run? Found these two here... Lunati or Comp cams both are dual springs.
http://www.ebay.com/itm/COMP-CAMS-GM...#ht_2258wt_947
or
http://www.atlanticspeed.com/product...ory=48#details
Running LS3 heads with LS3 intake valves and i want a .615ish lift cam
Thanks
Old Mar 16, 2012 | 04:59 PM
indianass's Avatar
i went with lunati i heard good things about them havent put them in yet tho
Old Mar 17, 2012 | 12:36 AM
any other thoughts?
Old Mar 17, 2012 | 01:11 AM
01ssreda4's Avatar
I'm running the Lunati's, on my second set actually. No complaints.
Old Mar 17, 2012 | 01:34 AM
underacheiver's Avatar
918's
Old Mar 17, 2012 | 02:15 AM
Originally Posted by underacheiver
918's
aren't 918's only good to .600 lift?
Old Mar 17, 2012 | 02:56 AM
Yes they are sorry I missed your 615ish part of your post.
Old Mar 17, 2012 | 05:26 AM
Jontall's Avatar
Can't go wrong with Lunati: http://www.lunatipower.com/Product.aspx?id=2584&gid=322
Old Mar 17, 2012 | 07:29 AM
Thumper28's Avatar
I just rebuilt my stock heads. Had them cleaned and got a valve job. I went super budget and got ls6 beehives new for about $60 so I can reuse my stock retainers. They are good for .580 lift which leaves plenty of moderate cams to choose from. Am I going to regret not going with a better set of springs?
Old Mar 17, 2012 | 08:20 AM
01ssreda4's Avatar
LS6 springs are not suitable for aftermarket cam lobes. They are designed for stock cam lobes. And 918s are now good to .625 lift but max lift is only one part of the equation. Just because your cam is under 625 lift does not mean a single spring will work with your application.
Old Mar 17, 2012 | 08:59 AM
baxsom's Avatar
scoggy dickins has their PAC 1215s good for .650 for the same price as the ones in the link last time i checked
Old Mar 17, 2012 | 09:26 AM
omc8's Avatar
LS6 springs are only good to .570 lift. But Lingenfelter has their LS9 springs that are good to .580 and they are only $70 http://www.lingenfelter.com/mm5/merc...Store_Code=LPE
Old Mar 17, 2012 | 03:01 PM
2QuikTA's Avatar
What about the PRC's?
Old Mar 17, 2012 | 07:05 PM
TVWilkes's Avatar
Prc x2!
Old Mar 17, 2012 | 09:13 PM
ZeeOSix's Avatar
PAC says 1215s are good to only 0.600" lift.
http://www.racingsprings.com/Store/P...?ProductID=205
I used PAC 1518s in my Z06 ... rest of the valve train is all stock except for some custom Manton pushrods and Trunnion Kit.
"High performance LS1 spring that features additional nitriding processing for increased durability for high lift applications up to 0.650 lift."
http://www.racingsprings.com/Store/P...?ProductID=220
Old Mar 18, 2012 | 08:12 AM
Thumper28's Avatar
I'm a little confused about the gt2-3 cam/spring combo. The description says it comes with ls6 springs but it has .571/.578 lift. Everywhere I read agrees with you that the ls6 springs are only good for .570" but I'm sure Lingenfelter has done extensive testing on this cam.
http://www.lingenfelter.com/mm5/merc...egory_Code=C31
Old Mar 18, 2012 | 09:23 AM
703 CAMAROSS's Avatar
What about Patriot Performance? Why has no one mentioned them?
Old Mar 18, 2012 | 12:24 PM
baxsom's Avatar
typo on my part the 1518s are 188.00 on that site.
Old Mar 18, 2012 | 12:31 PM
89ROC-Z's Avatar
patriot xtremes, there's a guy on here that sells them like $20 cheaper than anywhere else
Old Mar 18, 2012 | 02:25 PM
2QuikTA's Avatar
I'm guessing he's not a sponsor since you didn't provide a name?
