other pump options
other pump options
I recently swapped an LS1 into my '97 LT1 T/A. During the swap I swapped the stock LT1 fuel pump for a LT1 Racetronix pump and hotwire kit. I got the swap running last week. I took the car out on its first post swap drive yesterday and after about 10 miles the car died on me after I took a turn. I could not immediately get it started, I waited a few minutes and got it going again. I decided to head back home and on the way back the same thing happened several more times, until I was a block away from my house and it completely gave up on me. I can no longer hear the pump priming and I have confirmed that I still have power to it.
When I installed the pump I completely drained the tank of old fuel, and note that the tank was very clean. Now my question is this, should I risk buying another racetronix/walboro pump or is there any other options out there? I would hate to keep throwing $150 out the window with no warranty everytime it goes out.
Have you posted on our www.racetronix.info forum?
It is VERY rare for a pump to die like that, especially given that you seem to have installed it correctly. Typically early failures are due to installation error.
Yeah I'm going through the same issue when I still have the stock pump 94 impala ls1 swap a wot car felt like it cut off then I got a half block home too the car just shutoff... I'm about to go and get a racex
