is there a easy way to remove old gas ?
Old 03-26-2012, 07:04 PM
devic's Avatar
Default is there a easy way to remove old gas ?
i have a transam been setting up for a few years, and im finally getting around to fixing it, and was wondering if there is a easy way to remove all the old gas ?
or gas treatment maybe ?
Old 03-26-2012, 07:18 PM
99french's Avatar
Yup there is, take the quick disconnect clip off of your fuel filter. Place a rubber hose on end of fuel filter, turn the key on and let her pump away. Pump will start due to it trying to prime the fuel system. I dont see why that wouldn't work.
Or take a 1" drill bit and go to town.
Old 03-26-2012, 07:24 PM
TermnEatr's Avatar
When I needed to remove fuel I used a pump we use for race fuel that u hand crank but I have the trap door done also.
Old 03-26-2012, 11:49 PM
devic's Avatar
appreciate it man, and if it doest work might have to do that lol jk, but it would be a major pain to drop the tank just to get the gas out haha
should i stop before it get to complete empty so i dont suck up debris into the pump or damage it from running it dry ?
Old 03-27-2012, 03:46 AM
Breaking Stuff's Avatar
I once disconnected the return line on an f-150, added some hose and just let it run. Extracted 3/4 tank in about 15 min.
Old 03-27-2012, 09:56 AM
99french's Avatar
yea just get it low. guestimate about a gallon or two left and refill with good fresh fuel and you should be good to go. you can watch the fuel gage or have some one else watch it. i think you should have 2-3 gallons left when it hits the "E" mark on your gage. shouldnt take long at all.
Old 04-01-2012, 01:16 AM
time3777's Avatar
You can hook up a hose to your fuel rail pressure tap, it doesnt take long for it to pump out using that connection.
Old 04-04-2012, 03:58 PM
devic's Avatar
appreciate it guys =]
