how much can i narrow my rearend with bump stop mod like this...
im having a fab 9 built by midwest chassis and im trying to figure out how much i can narrow it. id like to go 1" on each side. im running 28x10.50 et drags with a 15x10 7.5"bs.
i have my bump stops removed & narrowed 3" a side........MWCFAB9.
check this out........
https://ls1tech.com/forums/gears-axl...rowed+rear+end
good luck!
good luck!
With a 28x10.5, you're definately filling out the fender well. Without extensively reworking the front part of the wheel "tub" an removing the bump top area, I'd say you're gonna be limited to narrowing only 1/2" - 3/4" per side.
You can narrow it more, I'm sure, but more work with the sawzall and bfh will be required.
