LS4 Performance - Will corvette Z05 rims fit on 08 Impala SS?
Barnett92
04-01-2012, 02:25 AM
I found a nice looking pair that was 5x4.75 inch. I believe the impala's to be 5x115, but I can only find the reading in mm!! Its an american car not a foreign car so why does it have to be in mm! Does any company make an adapter? Thanks for the help
ImpSS07
04-01-2012, 03:04 AM
No. They're 5x120. I'm pretty sure someone can or does make and adapter but you'd need to look for it.
WhiteGXP313
04-01-2012, 08:52 AM
they are prob way to wide to fit
Barnett92
04-01-2012, 05:35 PM
I hope they are not too wide :( maybe I can find some oem lookalikes that are more narrow.
V8ImpSS
04-01-2012, 07:25 PM
Unless you get blanks and have them custom drilled they're never going to fit. 5x114.3 = 5 1/2x5 and most will agree that 114.3x5 and 115x5 are interchangeable, but 5 3/4 = 120 mm...if you can get blanks I think the front ones would work all the way around...IIRC they're 18x8.5 on the C6Z and 17x8.5 on the C5Z
Barnett92
04-01-2012, 11:05 PM
Awesome! Thanks for the info, I will def look into this:)
Barnett92
04-01-2012, 11:12 PM
Ok, this will probably sound crazy, but how much work would it be to swap the hub on the car? I am not that talented of a mechanic (if you couldn't already tell). The main reason is to have the brake caliper and drilled rotor for looks, and if its the same size hub then should't the corvette rims bolt right on?
V8ImpSS
04-01-2012, 11:20 PM
there's no off the shelf hub to use that I was able to find when I went through all this...I'm still deciding on my next Rim/Tire combo to fit over the Camaro brembo's...gettting really sick of my snow tires :(
Let me know if you locate the C6Z wheels as blanks! I really want them! I'll hook you up on getting them drilled if you ship them directly to me and then I'll send you them drilled for 5x115
Barnett92
04-01-2012, 11:52 PM
I found a website called wheeladapter dot com that may be able to make an adapter that would fit. Maybe that would be your best bet too!
V8ImpSS
04-01-2012, 11:59 PM
I would never use any type of spacer on my own car, especially the drive wheels. that's just not safe, especially with how I drive. (like an ass hole)
plus the Vette Rims have a much lower offset, that they'd never fit with a spacer without widened fenders especially in back. they have a "built in spacer" if you will compaired to the stock rims...
only option is the blanks, I've spent hours researching wheel and tire combo's for this car and I'm leaning toward a 19x8.5 possibly 19x9 in front with offset similar to the stock front GXP wheels (18x8.5 +32mm)
Barnett92
04-02-2012, 12:02 AM
I didnt know how those spacers would fair. I will keep a lookout and hopefully locate some blanks! Wish me luck :)
