11 Second Club - 7.30 1/8 mile I reckon good for 11's
badblazeSS
04-05-2012, 02:49 PM
Finally got to make some passes this year with the TH400. This is not my best pass but the best i got on video. What would that be roughly in the 1/4?
7.37 @95mph
1.65 60ft
http://www.youtube.com/watch?v=UExceVIIBG8
SmallBlock 383
04-05-2012, 03:29 PM
Probably 11.40 -11.50's Nice Car man
lemons12
04-05-2012, 03:49 PM
11.4s possibly 11.3s.
Mods?
Kinda small on the converter?
89gmcs15
04-05-2012, 03:50 PM
11.59 @ 117 mph if what i get when i plug the numbers. not 100% exact but gets ya close http://www.wallaceracing.com/8th-quarter.php
VandykeT/A
04-05-2012, 06:09 PM
I ran 11.66 at 119-120 and 7.5 in the 1/8 at 95. 1.75 was my best 60 foot though.
badblazeSS
04-05-2012, 06:34 PM
Mods?
440whp
lq4
patriot ls6 heads
ls6 intake
pacesetters, magnaflow catback\
unknown th400
fti converter- footbrakes to 3600
torque arm, lca's 9" 4.11's
about 3800lbs
i havent launched off the transbrake yet and gonna spray 100 to it next time. I don't have a cage in yet so im not gonna spray the big shot just yet. Made 700hp on a 200
badblazeSS
04-05-2012, 06:35 PM
thanks, i think im gonna powdercoat my wheels black.
lemons12
04-07-2012, 10:19 AM
Nice man, you are on the heavy side so I would say high 7.4s/low 7.5s would be about right on.
You made 700Rwhp on a 200 hit? That is over a 250Rwhp gain, nice.
badblazeSS
04-07-2012, 12:06 PM
that was with the 6speed, it made 470hp. ive been a 7.30. gonna remove my swaybar and get some good tires and leave off the brake and try and get to some 7.1's
lemons12
04-07-2012, 04:58 PM
Sorry I meant 11* not 7*...
TurboStangJON
04-07-2012, 08:09 PM
Any idea on the converter serial number? Seems like it could use a little more...
01_ram-air
04-07-2012, 08:56 PM
I think you'll pick up if you have Greg re-stall the converter and loosen it up. However, I know someone running pretty much the same setup as you. Car runs ~ 11.3s on motor (with the nitrous tune... lots of timing taken out). However, I've seen it run 10.9s on motor with a different tune. LQ9, 200 shot, TH400, FTI converter. We've come to the conclusion it's a 3600 stall. He goes mid to high 1.6s on motor and low 1.3s off the Transbrake on the 200 shot. However, I feel he needs to have it loosened up to a 4200. FTI converters are tight which makes driveability nice. They're also efficient so you're not losing a lot on the top end. And they Love the nitrous. I told Greg to build me a converter for a 450 rwhp car on a 200-250 shot (future plans). And he did. My little ole stock motor was struggling with it. I'm pretty sure it was a 3500-3600 stall. I sent it back and had him restall it to 4200. Best 60' N/A has been a 1.60' which isn't bad for 305 rwhp. But, I've gone 1.41 60' off the Transbrake on a 150 shot that put down 424 rwhp. I'm 3600+ lbs raceweight.
So, my point is.. I bet that thing is going to hammer out of the hole on the Tbrake and juice. However, your N/A 60' will suffer quite a bit. IMO, you'll get the best of both if you loosen it up to at least a 4200 stall, if not, even higher.
TurboStangJON
04-07-2012, 10:49 PM
I'd just give Greg a call because I know it could use a little more stall speed. It should be going 1.50's on motor especially with that kind of power. You can have a happy medium between how it runs on motor and how it runs on the spray.
BLK95-Z
04-07-2012, 11:39 PM
Nice. Every time I go to the valley Im the only lsx, we need to hook up next time you go.
WongBob
04-08-2012, 12:14 AM
Mine runs 7.38s @ 91 and runs 11.6s. 11.3s would be about right.
gs462
04-08-2012, 12:43 AM
What cubic inch is the LQ4? and whats the compression?
lemons12
04-08-2012, 12:21 PM
what cubic inch is the lq4? And whats the compression?
364
9.4:1
gs462
04-08-2012, 05:22 PM
440whp
lq4
patriot ls6 heads
ls6 intake
unknown th400
about 3800lbs
I meant what cubic inch is THIs LQ4 and whats the compression??
badblazeSS
04-09-2012, 10:57 AM
if i ever spray it, they will surely kick me out. Let me know when you go. There is a lack of lsx cars down there and when i do see one it is stock. What kinda times you run? Just send me a pm and we will hook up. I plan on going to US 60 on the 21st for the no prep arm drop race and there is a track rental on the 28th there also. I am inviting you. Will be about 10 bucks. Come on down!
badblazeSS
408 around 11:1
badblazeSS
04-09-2012, 10:58 AM
Thanks for the input guys. I did talk to greg and gave him the serial number and all that jazz. He said it would be ok but not to run anything over a 200 shot. 3800 stall speed.
lemons12
04-09-2012, 01:30 PM
What kind of DA you running in? The weight can't be hurting you that bad I wouldn't think.
speedtigger
04-09-2012, 03:14 PM
This is about right.
LSxPwrDZ
04-09-2012, 04:15 PM
408 th400 7.30's??? I have a cam and bolt-on stock 110k mile LS1 full weight Formula that goes 7.20's @ 95 in the 1/8.
badblazeSS
04-09-2012, 06:38 PM
My top end is choking the cubic inches.
gs462
04-09-2012, 07:29 PM
408 around 11:1
Thanks I;m building a pretty similar LQ4, minus the stroker crank mine will be 370"
LSxPwrDZ
04-09-2012, 10:41 PM
Yeah I see that now... Went back and looked at the mods list. Get some nice heads cam and intake on that thing!
lemons12
04-09-2012, 11:31 PM
I ran almost identical times/mph with a 3500# 346 with hand ported heads/ls6 intake and a 226 .588 114 cam.
This doesn't mean shit, I'm just saying those numbers are a bit off IMO.
What was the DA?
badblazeSS
04-10-2012, 02:11 AM
Da was good. I think around 825
Slapattack
04-15-2012, 12:58 AM
nice pass man. I run 11.2's in the 1/4 and my 1/8 time is 7.2......so your deep in the 11's.
speedtigger
04-15-2012, 11:22 AM
You must have some big MPH for your ET.
Slapattack
04-15-2012, 11:39 AM
I dont know whats considered big but when I ran the 11.2 it was at 121mph with a 7.1 1/8 at 96 mph
speedtigger
04-15-2012, 11:59 AM
That is about 3 MPH stronger than most drag cars for an 11.2, you had originally said you ran 7.2 in the 1/8th, but now you said 7.1, so that is more typical.
EZZZE
04-29-2012, 10:50 PM
when my T/A went 7.33 in the eighth, it went 11.51 @ 118 in the quarter
