What happens if you leave the stock pushrods with a cam?
If I leave them in will it hurt anything immediately? Pushrods are at a friends house and hes kinda hard to get ahold of.
I've got another car to go get them he just works long hours and is hard to get in contact with to go pick them up. What I'm going to be doing is using a set of 10 thousandths milled 241s with the 650 lift prc springs and a torquer 2. When I went PRC 215s and MS4 on the T/A I had the torquer 2 and 241s left and he just forgot to send me the pushrods back when I picked my car and removed parts up. The car will be untuned for the drive home approx. 3 miles which would be the only distance it would be driven with the stock pushrods, very slowly to. I may be able to get ahold of him before tuesday or wednesday which is when I"m hoping to have my car back together by but if the worst happens would it be ok to drive it the 3 miles home as long as I take it easy?
I'm running stock 114k mile pushrods in my motor. Cam is a Patriot 225/229 .580/.590 114+4. Cam has about 30k miles on it. I spin to maybe 6700-6800 usually, and often. No valvetrain noise, still runs like a top. Stock lifters too!
damn that's suprising, but maybe it shouldn't be
Even though the cam in my camaro was small, I would have used stock push rods with most cams unless the lift was really extreme. Put about 25,000 on mine with lots of racing and WOT, 0 problems. Something about keeping the push rods as the weakest link made sense to me. Cheap to replace, fairly easy to replace, not a mechanical disaster if they go bad, less damage to engine if they go bad than if some other part of the valve train goes bad. Obviously they just won't work in some applications.
