Select Turbo Size
Select Turbo Size
Lets say 350ci redline of say 6000rpm.
Thats 516cfm (at 85% VE)
Say 8lbs of boost. Pressure Ratio of 1.55.
So at 8psi would need 800cfm.
So what turbo would work well with this?
A T76 would fall directly on the 70% efficiency line.
Now in regards to determining what you would use for twins how would you go about selecting those?
Would it be half the airflow but the same pressure ratio?
So ~30lbs/min at 1.55 PR?
A Y2K T-80 would fall into 70% island.
those borg waner,s 75mm work great 1100 hp if you get the right one that's what i would stick on it
