Generation IV Internal Engine - G6X3 & AFR 225 combo low numbers
r4104
04-16-2012, 06:36 AM
good day
im facing a low numbers of HP & TQ with my combo & dont know the reason
car details as shown below
corvette 2007 Z51 LS2 (forged)
Piston -2 (wisko )
Rods 6.125 (compostar)
heads gasket 0.040 (cometec )
Bore 4.005
AFR heads 225 62 cc
G6X3 CAM
Fast 102
dyno'd at 460 RWHP 400 TQ
on my search's car should achieve around 480 - 510 hp anyone know the reason of low numbers ? my tuner said that car timing is at 21 & air fuel is between 12.7 - 13
87silverbullet
04-16-2012, 08:17 AM
good day
Piston -2 (wisko )
Bore 4.005
AFR heads 225 62 cc
G6X3 CAM
Fast 102
You've provided good details but there are some we still need.
What kind of dyno? Dynojet? Mustang? Dyno Dynamics?
I'm assuming your car is a manual?
Just from waht you provided you timing is on the low side for N/A. Thats the kind of timing guys spray on and you A/F is a little lean but its not bad. I personally wouldn't run it that high, 12.5-12.8 would be a little more inline.
ringram
04-16-2012, 09:32 AM
Timing is low for sure.
What about exhaust?
SCR, DCR?
r4104
04-16-2012, 10:05 AM
It was in a dyno jet
I have c6 npp exhaust
Regarding timing how much it should be for n/a ??
What is SCR / DCR ?
And yes my car is manual z51
smokin91rs
04-16-2012, 10:40 AM
my ls3 g6x3 c5 trapped 128mph with 28 in it and with 22 my nitrous tune it was 122-123mph never dynoed it
redtan
04-16-2012, 10:41 AM
I would say that mid-high 400s is definitely the norm for stock cubed LS2s. You're in the lower of that range due to the seemingly poor tune...21* of timing? That's stock timing and is most definitely not what a close to max effort LS2 should be at.
I would say in the mid-high 20s is what it should have for timing. That alone could get you another 15rwhp which I would say is a good point for the car.
t/a98
04-16-2012, 11:10 AM
I have a g6x3 also and I was told by lg it was more of a stock-ish motor cam. I.e. not suited as well for upgraded heads and intakes manifolds. Also it is designed for ls3 heads which have very different flow characteristics than yours or stock ls2 heads... Maybe you should look into a different cam.
I mean I love mine, but it's in the motor it was designed for. They have te g5 series for ls2 and ls1 motors...
69blueSS
04-16-2012, 11:12 AM
Is head/cam selection not working as effeciently as they should either?
Isnt the G6x3 cam ment for rectangular port L92/LS3 headed engines and G5X3 for cathedral port
jack27
04-16-2012, 12:04 PM
Thanks for replaying guys
I am tge guy who tuned the vette
I rised the timing up to 25
I had some .9 kr
There was no gain in the Hp
This is the reson that i lowered it to 21
Because at 21
23
25
I had the same hp
This is the weird thing
venom ws7
04-16-2012, 12:43 PM
Do you guys have a dyno graph?
What headers?
with the same cam and botlons on M6 Z51 stock 243 heads a friend of mine dyno 465rwhp 418rwtq I beleive it was on 24 degrees of timing..
12.7 A/F ratio.
jack27
04-16-2012, 02:15 PM
Dyno grahp
The owner of the car have one
He should attach it
But on the dyno
After few pulls
The x-pipe has been opened
So the u might see a lean run
Its almost the same file for the 1st run
one fast zo6
04-16-2012, 02:31 PM
that cam is designed for ls3 heads which have very different flow characteristics than for your heads... Maybe you should look into a different cam. +1
87silverbullet
04-16-2012, 02:58 PM
I had some .9 kr
Because at 21
23
25
I had the same hp
Something is causing the knock then. Bad fuel? carbon on the pistons? Cam too big causing PTV?
The SCR is only 11.3:1 if the deck is 0 and the chamber is actually 62 cc.
The timing may be just fine. My modded LS2 timing works best at 20 degrees and makes 473 rwhp / 425 rwtq. More timing does not always give more power. All stock LS2 can take up to 26 degrees before knocking but if it makes max power at less, why add more? Listen to the tuner. With my mods, m car made no more power with more advance.
87silverbullet
04-17-2012, 07:39 AM
I understand that more timing doesn't always make more power but he was getting Knock at 23*. If a stock LS2 can take up 26* then an aftermarket headed motor should be able to get there with the same or less timing.
Your engine is a different animal. You are running stock heads and he is running AFR's which are a more efficient head. Plus listening to the tuner isn't always helpful some guys know what they're doing but alot do not.
quik95lt1
04-17-2012, 08:35 AM
fyi the ls2's do NOT like timing.......higher compression will like even less timing......a more efficent chamber will also add to it liking less timing due to faster burn rates...im in the same boat and made good power for what i have.......i run a mild 22x/23x street cam.....tuned the car my self and found that 21* was all the car wanted....i could get 23* into it but it made 0 more hp and 0 more torque so for RA load i dropped it back to 21.....this is not uncommon.......also that AFR is a bit leaner than usual....usually these motors like running down around 12.4-12.6.....at 13.0 i made 410 at 12.4 afr which is where mine is i made 422 cam only with supporting exhaust mods....
What does the MAP show during the WOT run start to finish?
Is it possible the WB is not calibrated properly, by chance did you try richening the AFR?
I always think if the cam was degreed when low power issue's come up.
I've two sets of AFR cylinder heads 205's & 230's, two different engine combinations, they always seem happy with high 20*'s & even 30*. That is 11.5 SCR on a Mustang that may load harder than the DJ. So I would agree the timing is low for those heads & a clue.
Detoxx03
04-18-2012, 07:11 PM
I think the numbers are fine for a LS2. If it was a LS3 then I would be scratching my head. I'd be more concerned with the timing issue.
82cetuner
04-18-2012, 07:49 PM
i also think the numbers are spot on, my 418 ls3 dynos 508 on a dynojet and it has a g6x3 cam and ported milled ls3 heads running the same compression are,
for you to be at 460hp thats pretty good for a stock cube ls2. i cant see you getting much more out of it without getting a cam specificly matched to the heads and intake setup. a g6x3 is going to perform best on a ls3 head and not saying you are losing power but its not going to be potimal for your heads. its still ging to make good numbers and good power and like i siad 460 isnt bad numbers.
msydow
04-18-2012, 08:05 PM
im still wondering about the kr. i dont tune, but have a very basic understanding for it. what were IAT's, coolant temp, and someone also mentioned bad fuel, but what about fuel pressure?
jack27
04-19-2012, 06:14 PM
Thanks guys for replaying
About the knock that i had
.9 or 1. I cant really remember
But that because i was running timimg up to 25
Something like that
And its not an issue
The other thing that the guy is looking at the dyno
Is
There was a stock car. Ls2 With stock short block
It had g6x3 and the same AFR head
For this car. The car dyno was 500
I havent tuned the 500 rwhp car
I havent even looked at the file
The owner used the car for few months then changed the car compo to supercharger
So the issue is
Same cars
Same heads
Same camshafts
One with piston and roads ( -2 or -3 )
Other is stock
My friend car is 460
The stock car is 500
This is what my friend trying to ask :)
r4104
04-27-2012, 04:34 AM
the latest news my piston -3.2 my compresion is 11.18 & i have attached the latest dyno sheet & tell me what do you think
SMOKINV8
04-27-2012, 05:32 AM
You could pick up some good torque below 4300rpm if you add some fuel. It's pretty lean and you can see the power pick up when it starts getting enough fuel to run.
Your tuner's methodology on pulling the timing back is good. You might try finding out what octane gas you had during your tuning session, vs. what the other guy had in his.
If you had the exact same bolt-ons it would be surprising to see that much of a difference, but I haven't seen any comparisons of the bolt-ons. Everything has to work together, so if you've got a bottleneck in the exhaust or intake path it's going to hold your power back. Are you running stock exhaust manifolds?
r4104
04-27-2012, 08:09 AM
I have vraram intake , 1/34 header kooks , c6 npp exhaust , fast 102
Both same fuel
After calculation i found that we both have same compresion
He have stock short block with AFR heads 62 CC
ducatisl
04-27-2012, 08:26 PM
Count me as another who used to run high timing (28*) but on the dyno tuning for nitrous recently, my tuner and I discovered that low timing (21.5*) was perfectly fine with no loss in power. Car is cam'd (224/236) LS3, stock heads.
LS2-wise, a friend i race with has a ported head/cam LS2 in a C6, and he lays down 505, but I believe that's on a Dynojet. I lay down 468 on a Mustang.
Maybe your intake/exhaust combination is not working as well as what's on the other car.
yelw 06 z51
04-27-2012, 09:48 PM
Something like that
Is
So the issue is
Same cars
Same heads
Same camshafts
Other is stock
The numbers are a little low. LSCHLEM on corvetteforum got 500+ hp ( I think around 460 tq) on stock ls2 block with ported fast 102 and a smaller 228 cam. He also had 59cc heads though not sure on the size of the head gaskets.
r4104
04-29-2012, 01:26 PM
this car is driving me crazy. i think there is something wrong with it because it knocks at 23 timing ... what can cause knocks ? my plugs, wire's new fuel cycle is not high what it could be ?
djjonesivs
05-02-2012, 07:52 PM
http://i246.photobucket.com/albums/gg111/djjonesivs/909b9de8.jpg
Ls2
Etp 215
M6
19* -21 *timing 13.0:1 afr
6600rpm limiter
503 451
More in it at higher rpms
Had 24-26* before cam only
Dropped the timing made more power due to air flow efficiency
Probably 11-11.5 for scr
