G6X3 & AFR 225 combo low numbers
good day
im facing a low numbers of HP & TQ with my combo & dont know the reason
car details as shown below
corvette 2007 Z51 LS2 (forged)
Piston -2 (wisko )
Rods 6.125 (compostar)
heads gasket 0.040 (cometec )
Bore 4.005
AFR heads 225 62 cc
G6X3 CAM
Fast 102
dyno'd at 460 RWHP 400 TQ
on my search's car should achieve around 480 - 510 hp anyone know the reason of low numbers ? my tuner said that car timing is at 21 & air fuel is between 12.7 - 13
Piston -2 (wisko )
Bore 4.005
AFR heads 225 62 cc
G6X3 CAM
Fast 102
good day
Piston -2 (wisko )
Bore 4.005
AFR heads 225 62 cc
G6X3 CAM
Fast 102
Piston -2 (wisko )
Bore 4.005
AFR heads 225 62 cc
G6X3 CAM
Fast 102
What kind of dyno? Dynojet? Mustang? Dyno Dynamics?
I'm assuming your car is a manual?
Just from waht you provided you timing is on the low side for N/A. Thats the kind of timing guys spray on and you A/F is a little lean but its not bad. I personally wouldn't run it that high, 12.5-12.8 would be a little more inline.
I would say in the mid-high 20s is what it should have for timing. That alone could get you another 15rwhp which I would say is a good point for the car.
I have a g6x3 also and I was told by lg it was more of a stock-ish motor cam. I.e. not suited as well for upgraded heads and intakes manifolds. Also it is designed for ls3 heads which have very different flow characteristics than yours or stock ls2 heads... Maybe you should look into a different cam.
I mean I love mine, but it's in the motor it was designed for. They have te g5 series for ls2 and ls1 motors...
Thanks for replaying guys
I am tge guy who tuned the vette
I rised the timing up to 25
I had some .9 kr
There was no gain in the Hp
This is the reson that i lowered it to 21
Because at 21
23
25
I had the same hp
This is the weird thing
I had some .9 kr
Because at 21
23
25
I had the same hp
Dyno grahp
The owner of the car have one
He should attach it
But on the dyno
After few pulls
The x-pipe has been opened
So the u might see a lean run
Its almost the same file for the 1st run
He should attach it
But on the dyno
After few pulls
The timing may be just fine. My modded LS2 timing works best at 20 degrees and makes 473 rwhp / 425 rwtq. More timing does not always give more power. All stock LS2 can take up to 26 degrees before knocking but if it makes max power at less, why add more? Listen to the tuner. With my mods, m car made no more power with more advance.
Your engine is a different animal. You are running stock heads and he is running AFR's which are a more efficient head. Plus listening to the tuner isn't always helpful some guys know what they're doing but alot do not.
fyi the ls2's do NOT like timing.......higher compression will like even less timing......a more efficent chamber will also add to it liking less timing due to faster burn rates...im in the same boat and made good power for what i have.......i run a mild 22x/23x street cam.....tuned the car my self and found that 21* was all the car wanted....i could get 23* into it but it made 0 more hp and 0 more torque so for RA load i dropped it back to 21.....this is not uncommon.......also that AFR is a bit leaner than usual....usually these motors like running down around 12.4-12.6.....at 13.0 i made 410 at 12.4 afr which is where mine is i made 422 cam only with supporting exhaust mods....
What does the MAP show during the WOT run start to finish?
Is it possible the WB is not calibrated properly, by chance did you try richening the AFR?
I always think if the cam was degreed when low power issue's come up.
I've two sets of AFR cylinder heads 205's & 230's, two different engine combinations, they always seem happy with high 20*'s & even 30*. That is 11.5 SCR on a Mustang that may load harder than the DJ. So I would agree the timing is low for those heads & a clue.
i also think the numbers are spot on, my 418 ls3 dynos 508 on a dynojet and it has a g6x3 cam and ported milled ls3 heads running the same compression are,
for you to be at 460hp thats pretty good for a stock cube ls2. i cant see you getting much more out of it without getting a cam specificly matched to the heads and intake setup. a g6x3 is going to perform best on a ls3 head and not saying you are losing power but its not going to be potimal for your heads. its still ging to make good numbers and good power and like i siad 460 isnt bad numbers.
im still wondering about the kr. i dont tune, but have a very basic understanding for it. what were IAT's, coolant temp, and someone also mentioned bad fuel, but what about fuel pressure?
