Front tire size ?
Old 04-18-2012, 09:12 PM
simplysix's Avatar
Default Front tire size ?
Hello all. I'm a little confused on front tire size. Seems like 275 is most popular but I don't understand why. Only advantage I could think of is increased Cornering ability, but a lot of people are pulling off the front sway bar so Cornering must not be the goal. Is it just a style thing? I would something like a 245 would be cheaper, lighter, and have less rolling resistance, so what's the advantage of a wider front tire?
Old 04-18-2012, 09:34 PM
TransAmWS.6's Avatar
It really kind of depends, if you just want to go fast in a straight line, then I suppose it may be kind of pointless to run a 275+ tire up front unless you just want it for the looks. In the handling department however, I believe, theoretically the wider the tire you have the better traction you will get. Most of the seriously fast F-Bodies I see that are setup for road-racing always run huge tires up front, so I'm pretty sure there are some actual advantages to it.
Old 04-18-2012, 11:17 PM
02TransAm/Batmobile's Avatar
Most people are running 275's because that's the correct width for their stock rims. The most popular aftermarket rims for the 98-02 F-Bodies seem to be Corvette replicas because of their affordability and they themselves also come in at around the same rim width - thus requiring a 275 tire.
There are some people who are more straightline-oriented that opt for a thinner front wheel like the 17 x 7 street lights. I think the recommended size is 245 on those.
Basically, a large percentage of owners have a rim that requires a 275 width rim. It is dangerous to run a 245 width tire on a factory rim much like it is dangerous to run a 315 width tire on aforementioned rim.
Old 04-18-2012, 11:44 PM
carlos64030's Avatar
Your statement I bolded is very misleading considering how the Camaro Z28, Formula and Trans Am models comes with 245-50-16 tires on 16 x 8 wheels.
Old 04-19-2012, 11:19 PM
Yea, I forgot about factory 16's. I meant it's dangerous to run a 245 width on a rim that requires 275's.
Old 04-20-2012, 02:54 AM
99Bluz28's Avatar
02TransAm/Batmobile,
There's no danger in running a 245/45/17 tire on a 9" wide wheel, most if not all Manufactures recommended wheel width range is 7.5"-9", and with a 245/40/18 tire you can safely use a 9.5" wide wheel.
Old 04-20-2012, 10:28 AM
mikey67's Avatar
I have 245's on my 9" wide front wheels, it's a non-issue they fit fine.
Old 04-20-2012, 12:54 PM
That, I did not know. Would a 245/40R18 tire look stretched on a 9.5"? I have 275/40R18's on my front 18x9.5's and I was afraid 265's alone would look stretched.
Old 04-20-2012, 01:21 PM
99Bluz28's Avatar
Yeah, it probably would, but that still depends somewhat on how wide the tire runs since the width varies from different brands.
Old 04-21-2012, 12:58 PM
Mtownls1's Avatar
give it the hella flush look lol
Old 04-22-2012, 07:34 AM
mikey67's Avatar
245 would probably be okay on a 9.5" wheel. 245mm translates to just over 9.5 ". That said, a 9" wheel is typically the widest recommended wheel width for a 245 so it might be pushing it a bit... 99Bluz28 has a valid point about tire widths not being consistent from brand to brand. A 265 would be fine on a 9.5" width wheel.
Quick Reply: Front tire size ?
