Who sells AJE Crossmember for Fox LS swap ?
Old 04-19-2012, 08:41 PM
mike m's Avatar
Default Who sells AJE Crossmember for Fox LS swap ?
I am looking to buy the AJE cross member, a arms, Headers, and caster camber plates. Is there a sponsor on here who sells all of this or should I just buy from summit. Does anyone know the proper part #'s if I order from Summit ? Thanks
Old 04-19-2012, 09:25 PM
woopow's Avatar
what engine and tranny combo?
Old 04-19-2012, 09:33 PM
woopow's Avatar
http://www.ajeracing.com/MustangCompleteKits.php
i bought mine from them directly...headers i plan to purchase 351w long tubes for the fox chassis with 1 3/4 primaries and cut the primaries flange off and weld on flanges for the ls
Old 04-19-2012, 09:53 PM
mike m's Avatar
I'm doing a 6.0 and using the c4 with the jw bellhousing.
Old 04-20-2012, 11:42 AM
woopow's Avatar
Sounds nice...only considering factor to me will be tranny k member...unless you can adjust engine mounts or kfor member to compensate the difference...but its possible your jw housing has the difference designed into it..idk
Old 04-20-2012, 12:14 PM
woopow's Avatar
If you decide not to alter tranny mounting location to keep same driveshaft length and such... good alternative to engine placement is using adjustable engine mounts like from www.dirtydingo.com
have friend that uses a set and solved alot of figment issues with his engine/tranny combo
Just throwing some other info out there hope its helpful
Old 04-20-2012, 09:12 PM
mike m's Avatar
Was that on a Fox body? They only list for 96 up. I can see how the adjustable ones would help out with fitment. It has been done with a stock trans mount and just extended the mounting plate. Gotta wonder about header fitment then too. I will call them up next week.
Old 04-21-2012, 05:57 PM
woopow's Avatar
Found out aje has a tranny k member for c4...
simple now...aje #s
k member- mu-40um...280$
Trans crossmember- mu-7050...159$
mounts- aje30...69$
C.c. plates- mu-8000...179$
A-Arms would depend on front suspension you want to go with..stock style coil or coil over conversion..im sorry for the mishap...
Old 04-21-2012, 07:16 PM
Gray86hatch's Avatar
Call and get Team Z stuff. way nicer stuff.
Tim
Old 04-22-2012, 10:24 AM
mike m's Avatar
Tim
Will the Kooks or dynatech headers fit with their K member ? And what did you do for trans member for the C4 ? Thanks.
Old 04-22-2012, 10:56 AM
Dynatech will fit.
Stock trans crossmember.
Tim
Old 04-22-2012, 12:56 PM
mike m's Avatar
Dynatech will fit.
Tim
The car currently has the c4 in it. That would be awesome if I don't have to modify the trans member. Looks like I have my parts list. Gonna make some calls on monday.
Old 04-22-2012, 01:11 PM
You may have to cut the tubes loose on the crossmember like I did 10 years ago and never rewelded.
Team Z mounts can locate the engine where you want it fwd-aft then just weld the lsx part to the mount and it is good to go. Dave and I talked about this when I was overthere a few months ago.
It is a quick and easy fit saves a bunch of $$ on this swap.
Tim
Quick Reply: Who sells AJE Crossmember for Fox LS swap ?
