Rocker Arm Conversion Question
Old 04-19-2012, 09:25 PM
C_Rules's Avatar
Default Rocker Arm Conversion Question
Has anyone upgraded to the bigger 7/16 studs? If so what parts did you use?
Old 04-19-2012, 09:46 PM
F0x Slaughter's Avatar
All you need is the studs. ARP is usually the choice. The holes are 7/16 the top of the stud is 3/8 factory and the 7/16 studs are 7/16 top and bottom.
Old 04-19-2012, 09:57 PM
James Montigny's Avatar
ARP Pro series 7/16" studs have served me well through several builds.
PN ARP 234-7202
Remember to seal the threads when you install them.
Old 04-20-2012, 07:16 AM
C_Rules's Avatar
PN ARP 234-7202
thanks for the part number.
i see the rocker arm nut thread length is .67 inches. does it screw deep enough into you rocker arms or is it a bit shallow?
i had to shim my old 3/8 setup because it was too shallow.
Old 04-20-2012, 08:43 AM
It was enough for stock valves and pushrods with Pro Mags, they were too short for the
longer ones I used with the Dart castings. I ended up using taller studs.
Most people will never run into that issue.
Old 04-20-2012, 09:16 AM
C_Rules's Avatar
ok, looks like measurements will have to be made. what rockers did you go with?
Old 04-20-2012, 10:14 AM
I used Comp Pro Mags; Ultra Pros didn't exist at the time.
In retrospect, I should have machined he heads for shaft-mount Jesel rockers while I had it apart.
It really would have simplified geometry for me.
