help with piston rings>!!!
Restricted User
i am building a 6.0 and my top ring is skinnier than the second ring. which is 1.5mm. the oil ring is also skinnier than 3mm so my standard rings i bought will not work. i thought it was a stock piston, its standard bore. im so confused and need this truck back on the road. please help me, the block was supposed to be a 2007. the rods and pistons are floating pins if that helps
Restricted User
i found on summit a set that im pretty sure i need, they are
1.2mm top
1.5 second
2.5 oiling rinng.
they are 40$ per piston, there is no way im paying that, what are my other options? i need this truck back on the road yesterday.
1.2mm top
1.5 second
2.5 oiling rinng.
