Generation IV Internal Engine - LS2 w/ LS3 heads, Is this a smart move for $600???
connecticut
04-21-2012, 09:06 AM
Motor: LS2/402, Eagle crank/rods, Mahle pistons, Dart Pro Heads
Cam: Crower 622/609 238/246 112LSA (may change to suit LS3 needs)
Car: 2003 C5Z06
Tuner: Don Kinder has been tuning my builds since 2006
Why? Dart Pro's, I know nothing about them, but have been told(key word here) that they are just above 243's
Plan: remove the Dart's and install the LS3 heads(take-off), the LS3 intake/90mmTB cost is not an issue(the LS6 intake would cover it if sold)
1. LS3 heads($600)
2. LS3 intake/90 ($300-400)
3. Cam ($350)
Thanks for the info:usa:
COPO9560
04-21-2012, 09:33 AM
If you go to the efforts to install the LS3 heads, you might consider having them ported before bolting them on. Lots of options here.
Can't address the Dart heads - don't read much about them in LS series.
flash911
04-21-2012, 01:15 PM
If budget is not the main concern I would. I'd get 'em ported (by a pro) too since you have a few extra cubes. As mentioned, a cam too while you're at it...
bww3588
04-21-2012, 05:29 PM
the cam you have will compliment the LS3 heads nicely.
litle88
04-21-2012, 06:53 PM
I agree with this POS^^^^ :jest:
I Also believe that you should get them out to LPE, TEA or a porter that knows what he's doing with Ls3 heads.
You can save money by going to the Camaro5 forums. Those idiots over there are selling intakes for 150 with fuel rails and injectors lol.
GL
connecticut
04-21-2012, 07:04 PM
LS3 head porting.............
typical LS3 porting starts at $1200..............I'd take the 1200 and sell the LS3's for 600, net 1800 and buy AFR or TFS., Basically 2400 vs 1800 if I went the LS3 ported route
I'm not spending $1200 to port GM castings.
Johnnystock
04-21-2012, 08:19 PM
well I got a set of hand ported LS3 for 1400$...but for 1800$ I would consider AFR or TFS too...
gtotoocool1
04-22-2012, 09:18 AM
don't know anything about the Darts.but the L92s straight from GM flow enough air(over 300cfm) to support about 600hp.unless your trying to build a max effort deal,you don't need to port the L92s,period.if it was me,i would just mill(or not)for desired compression,have the guides checked, get a good VJ and bolt them on.
Tainted
04-22-2012, 10:12 AM
Dont forget you need the offset rockers and stands also.
connecticut
04-23-2012, 11:03 AM
still lookin for knowledge, I have zero on the LS3 heads except form what I've read here...
again, TFS and AFR no doubt are the way to go, but to invest 2400 into a C5? I'd sell the car and find a 20k C6
the CNC shops aren't going to make money giving the thumbs up on 'untouched' LS3 heads for a smart option
A_VAS
04-23-2012, 11:17 AM
good valve job, and run them. I think they will be a better match for a 402 stroker than the Darts....will pickup upper end hp and you won't notice much difference down low
Johnnystock
04-23-2012, 02:29 PM
Stock LS3 heads with and LS3 intake is better than the LS6/Darts for a 402, so you will see a difference in hp, I'm pretty sure. But you could get your Darts heads fully ported and a FAST, but I dont know if youre gonna save money here..FAST is expensive. LS3 is a sure bet.
gtotoocool1
04-23-2012, 03:50 PM
the CNC shops aren't going to make money giving the thumbs up on 'untouched' LS3 heads for a smart optionof course not.but a good shop will sell you a VJ if that's all you want,and there are gains in that. how much HP will you gain from porting?what are the airflow requirements of your engine?do a little research,you'll find there are people that have strong motors with unported L92s.
connecticut
04-24-2012, 01:59 PM
ported LS3/92's, FAST, AFR, TFS are not on the list here.(not putting $$ into a C5Z)
TransWS6Am
04-24-2012, 04:18 PM
why not? they will flow as well or better than say a AFR 225.
connecticut
04-24-2012, 05:23 PM
If ported LS3's outflowed AFR225's...........then wouldn't the LS world abandon the aftermarket castings and just buy worked LS3 heads all day long?
I think my post is a bit confusing
Can I expect 500whp out of the 402LS2 with the LS3heads/intake and correct cam?
Tainted
04-24-2012, 05:28 PM
According to Pat G, Tony and a few others its not all about the flow. With the small bore of the ls2 theres a lot of valve shrouding with ls3 heads and ptv clearance is tight, so milling for loss of compression isnt an option unless you flycut
Tainted
04-24-2012, 05:31 PM
With your bigger cubes, and larger bore yes 500rwhp should be no problem.
Che70velle
04-24-2012, 08:11 PM
With the correct cam, and tuning,yes.
TransWS6Am
04-24-2012, 08:54 PM
uh yeah, hence why there are ton of guys running ported LS3's. I had AFR 225's before i got my ported LS3's.
Black_Phantom
05-03-2012, 12:18 PM
i made 460rwhp with LS2 block LS3 heads MS4 cam and Holley hi ram intake Holley HP EFI.
be sure to get high lift cam with this small bore.
G8-4-speed
05-04-2012, 07:10 AM
Would make sure to check PTV clearance to make sure the valve reliefs in the pistons match up ok with that cam. Shouldn't be an issue but worth checking. LS3 heads respond better to high lift over duration.
