Generation III External Engine - Removinng the Rasp?
View Full Version : Removinng the Rasp?
arapitis
04-21-2012, 12:22 PM
I'm going to be seeing an LS1 expert this week, but I'd still like to still see what anyone thinks about my predicament. I have a 2000 WS6 Trans am with Flowtech long tube headers, Off-road Y Pipe, and straight pipe (SLP Loudmouth w/o the resonator) the rest of the way back...no cats, resonators, mufflers...nothing. I like the volume and overall tone, but as is apparently common for these cars, the rasp that comes just before the shift is terrible. Does anyone have any suggestions as to how I can eliminate the rasp as much as possible without turning the overall volume way down?
arapitis
04-21-2012, 12:29 PM
by the way...I heard once that adding a high-flow cat would reduce the rasp significantly....i was thinking about putting one of these on the straight pipe...thoughts?
http://www.ebay.com/itm/3-Magnaflow-Universal-59959-Catalytic-Converter-High-Flow-Spun-Metallic-Cat-/110847989857?pt=Motors_Car_Truck_Parts_Accessories&hash=item19cf0e1861&vxp=mtr
01transampower
04-21-2012, 12:55 PM
The y-pipe is what causes the rasp. So your best bet is to either try the cat in the I pipe or run a muffler again. I had basically the same set up and hated the rasp. Now I took all that out and put true duals on. Sounds amazing. I have 2 high frlow cats an x-pipe and 2 dynomax bullet mufflers.
arapitis
04-21-2012, 01:19 PM
well...since i dont have the budget for all of that...you would suggest the cat i was thinking about or a bullet muffler on the straight pipe? which do you think would reduce the rasp more and maintain a good tone for the exhaust over all
Mattyfresh89
04-21-2012, 01:25 PM
I have BBK LTs and the 3" off road Y pipe mated to a SLP LM1 with the bullet muffler still attached. Its raspy as a bastard......
strangely enough I remember test driving the car, after the install, with the LTs bolted to the ORY and it wasnt as raspy... Leads me to believe its something to do with the cat back set up, hmmm
01transampower
04-21-2012, 01:34 PM
I had a bullet muffler put in my I-pipe and like Mattyfresh89 said it didn't do shit. The flow through design doesnt do much. I would go with a single cat like you have there or maybe one on each side like a typical set up.
Check these guys out too: http://performance-curve.com/
arapitis
04-21-2012, 01:37 PM
thanks for the info. im leaning toward the cat anyway...do you think itll kill the overall volume too much?
Mattyfresh89
04-21-2012, 01:41 PM
doubtful, it will obviously take some volume away.
Only example I have is my buddys gto, although its LS2, full exhaust with a high flow cat ==> SOUNDS AWESOME! (true dual though, x pipe to Corssa)
I've heard other gto's with a similar set up with "fake cats" or no cats and they dont sound as tight
01transampower
04-21-2012, 01:45 PM
Yea you may loose a little tone but like Mattyfresh89 it'll probably tighten it up and let you hear the exhaust. not the rasp.
arapitis
alrighty...i know ill lose some sound...but as long as the rasp is reduced more than the the rest ill be ok lol. the link you gave me above...do you recommend them from personal experience or just because its cheap and appears to be good? ive used magnaflow cats before and was very pleased so im inclined to go with that one...unless you have info to the contrary.
im not a total noob when it comes to exhaust...just this whole rasp situation lol.
arapitis
04-21-2012, 01:46 PM
i was referring to the link from 01ta...not matty. sorry for the confusion
BOBS99SS
04-21-2012, 01:58 PM
you remove rasp by removing the y pipe, lm1 is the worst exhaust for a modded car, honest i have had alot of catbacks , they dont even compare to a good dual setup
arapitis
04-21-2012, 02:05 PM
well...my brother has a camaro with the lm1 setup but he has the "muffler" and the cats and his sounds perfect. since the muffler isnt super impactful...im thinking the cat should make enough of a difference....besides, at this point...im not running an slp kit...its just 3 inch pipe everywhere except the tail pipes
01transampower
04-21-2012, 02:08 PM
I have experience with them. Great bang for the buck. I live in colorado and still have emissions and they still allow me to pass even being high-flow. I have one on each side off my headers.
arapitis
04-21-2012, 02:12 PM
cool..you dont have to have experience with the magnaflow too do you? that would be perfect hahaha. which model did you use?
01transampower
04-21-2012, 02:17 PM
No no experience with magnaflow lol sorry.
http://performance-curve.com/2goerlichcatalyticconverterobdii608214-1-1-1.aspx
mine are about 2 years old so not the stainless versions but same design.
arapitis
04-21-2012, 02:21 PM
sweet. thanks a lot. do you have a pic of where you placed them in the system?
adamantium
04-21-2012, 02:36 PM
What type of ORY do you have?
01transampower
04-21-2012, 02:41 PM
<a href="http://s1050.photobucket.com/albums/s412/01transampower/?action=view&amp;current=101_1115.jpg" target="_blank"><img src="http://i1050.photobucket.com/albums/s412/01transampower/101_1115.jpg" border="0" alt="Photobucket"></a>
Now with my Poly motor mounts and my Jet Hot headers my driver side header sits close to the floor pan so the cat had to be moved back further in the system but still serves its purpose. As you can see the passenger side is fine. Most of the time it sould fit right after the collector.
01transampower
04-21-2012, 02:42 PM
arapitis
04-21-2012, 02:45 PM
no clue..it was there when i got the car
arapitis
04-21-2012, 02:46 PM
i have flanges where your cats are. maybe ill just cut them out and weld the cats right in place like you did.
adamantium
04-21-2012, 02:50 PM
a $40 flow master y merge eliminates rasp from what i hear and its a GREAT looking merge. Take a pic of your ORY maybe someone can tell you what brand Y it is.
01transampower
04-21-2012, 02:54 PM
That would work good since you already got flanges. I wanted flanges but no room with the driver side header so close to the floor. But it should work great for you.
arapitis
04-21-2012, 02:56 PM
well i was thinking about just replacing the flanges with the cats since the cats would need to have flanges weld on to be used anyway
01transampower
04-21-2012, 03:10 PM
True. very tue.
arapitis
04-21-2012, 03:12 PM
True. very tue.
i figure that everything else is welded so why not go for the whole shebang.
01transampower
04-21-2012, 03:27 PM
yea exhaust leaks suck. thats why all of mine is welded too. the only place it not is the slip fit on the header collectors and the flanges on the back where th pipes run under the axel and out the back.
arapitis
04-21-2012, 03:59 PM
its funny you say that. my brother and i were just talkign and decided it would be best to use a slip clamp on the headers end of the new cats and just weld them on to the y-pipe. i just hope there is room enough in front of the o2 sensors on the y. i wish i could get a pic of it...or even look under there right now so i could do some measuring. damn low cars
01transampower
04-21-2012, 09:32 PM
See i deleted my rear 02's and only have the fronts. You should be able to see taht in the picture. You should be ok using the slip fit style.
arapitis
04-21-2012, 09:43 PM
tbh...i dont remember whats down there on my car. i didnt do that part of the exhaust so ill have to check. i think i have it like yours though
01transampower
04-21-2012, 10:10 PM
If you have them and keep them then i would but if you have to pul the back o2's dont worry they dont do anyhting anyway. they make sims to foo the computer they're there or you can get them tuned out. If you have them if not it'll be all the more asier lol.
MikeWS6
04-22-2012, 08:32 AM
i use to have thunder bolt cats on my lm1 with long tubes. there was no rasp at all. i now have an ory and there is some rasp but its much louder. pick ur poision lol
arapitis
04-22-2012, 10:22 AM
well, unless there is a batch of them up pretty high on the headers, i only have the one set...on the headers' collector i believe
arapitis
04-22-2012, 10:23 AM
so what youre saying is that with my longtube headers, ory, straight 3 inch pipe to the 2.5 in tailpipes...with a set of thunderbolt cats after the headers, itll sound nice and loud/good with a just a bit of rasp?
MikeWS6
04-22-2012, 12:11 PM
The cats will kill all the poping and rasp if thats what you dont like.
arapitis
04-22-2012, 12:58 PM
thats the plan. what are your thoughts on how much the thunderbolt cats will effect the overall volume though?
01transampower
04-22-2012, 08:39 PM
Your rear o2's have been deleted then already so no need to worry about them then.
