Forced Induction - lsa cam
View Full Version : lsa cam
toughy v8
04-21-2012, 05:48 PM
are any of you guys using and what is needed to fit it to a 2001 ls1?
Konman93
04-21-2012, 11:37 PM
I dont understand your question.
usmcpi
04-22-2012, 01:10 AM
Im pretty sure he is asking if you can put a 09+ CTS-V (engine = LSA) cam in his LS1. Sorry, i can only decipher your question, but dont have an actual answer for you. However, I believe the LSA cam is a single bolt (but i could be wrong), your LS1 has a 3 bolt cam. Why not just get a blower cam designed for the ls1?
toughy v8
04-22-2012, 03:57 AM
yeah sorry i should of made it clearer i do mean the cadillac cts v cam i was just wanting to know if this was any good as a budget turbo cam as i have found one for sale and its cheap, and what would i need to fit this cam to my ls1 thanks.
stevieturbo
04-22-2012, 04:24 AM
pretty sure lingenfelter do the parts needed to use these cams.
sparkwirez06
04-22-2012, 08:15 AM
it's not a budjet cam ,when you have to change your front cover, sensor ect to make it work.
just put a zo6 cam in it.
Dynospeed
04-22-2012, 12:23 PM
the lsa cam is a turd. we throw them in the trash can. at least do a ls9 cam. Dont even bother with these cams without running ls3 style heads. truely a proper camshaft for $400 is well worth the money.
02anti_vnm
04-22-2012, 12:40 PM
I agree with these guys even with the pennies saved, by the time you convert everything youll have more in it then a custom spec'd cam just for you for around $425. if thats still outa the budget go with a used ls6 cam for around 200ish
