Generation III External Engine - fuel pump removal help
ghostws6
04-22-2012, 02:40 PM
i have a 2002 ws6 that i have been working on for a year got the motor in everything hooked up new gas then tried to start it and all it did was crank no turn over so had a buddy help me out and no fuel pressure and the fuel pump isnt kicking on so ordering a new one from summit and was looking at it and am wondering which is easiest and better in the long run remove the exhaust and drop the tank or cut a trap door to remove it
dont z20h8
04-22-2012, 02:42 PM
cut a access panel under the carpet in the rear much easier
S10xGN
04-22-2012, 09:17 PM
Can we ASSume you checked the obvious stuff like relays and fuses?
ghostws6
04-22-2012, 11:08 PM
yes yes that i did and just picked up a walbro 255 today just now to get a cut off wheel and cut a access panel
sjsingle1
04-23-2012, 12:06 AM
be a man.......drop the tank
dodson55
04-23-2012, 08:59 AM
cut the access hole i dropped a tank once after that i said never again lol
If you have the tools and time, I agree. When I pulled my tank years ago it took maybe two hours tops. But when I got stuck 1500 miles from home, I had to cut the panel. :(
mike171562
04-23-2012, 11:55 AM
You will be glad you cut the panel if a hose pops off or something and you have to get back in there.
Cut a access hole, and make sure the Walbro pump you bought is the direct fit one thats for 99-02 (http://www.ws6project.com/user_stor/catalog/99-02-walbro-direct-fit-fuel-pump/) only, if its the one thats for 93-02's (http://www.ws6project.com/user_stor/catalog/93-02-ls1-lt1-walbro-255-lph-in-tank-fuel-pump/) you'll have to modify part of your gas tank and it wont work as good.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
