Forced Induction - ls oil return
sum guy
04-23-2012, 06:13 AM
I'm planning a single tubo on my lq9. Laying everything out in my head right now. Where are you guys running the oil retun to?
BottleFedZ346
04-23-2012, 06:22 AM
On my setup the drain goes to the timing cover, Depends on the location of your turbo......
denmah
04-23-2012, 07:19 AM
ding!
it can go anywhere there is oil, so long as you are above oil level you'll be fine.
we return the oil from my friends remote mounted silverado to his oil fill cap
x275radial
04-23-2012, 07:25 AM
damn how high is the turbo that you went to the oil fill
Slow94Formula
04-23-2012, 09:22 AM
Remote mount = scavenging pump.
mconway68w
04-23-2012, 10:25 AM
If you use a pump, you can return any where from the heads to the oil pan.
BlwnLs1GTO
04-23-2012, 11:25 AM
I just tapped right into the Oil fill port on the valve cover. I tapped in a 3/8 NPT hole at the very bottom where there's a lot of material for threads.
I also use a oil pump on mine. (front mount though)
sum guy
04-23-2012, 09:45 PM
I was thinking timing cover or oil pan. This will be a signifigant part of the turbo build to r&r either and weld on fitting. Hopeing there was an easy button. On some 6.0 (escalades I know) have a oil coolers bolted to the pan above oil filter. One pipe would have to be pressure and one a return. Might could run both oil lines from there. My main concern is the turbo will be high on the right side and cooler mount is low on left, probly not down hill enough. Anybody ever try this?
91sonomast
04-23-2012, 09:58 PM
What about that fancy plate above the oil filter? What's up with that guy? Wait, I'm asking what this guy is asking ^
Adam86
04-23-2012, 10:49 PM
If I could go back I would have gone with the oil pan when the motor was out of the car. With the motor in the car, I would say timing cover would be easiest. Best to take the pan off to clean out the shavings. The timing cover doesn't leave a lot of room between the return line and the crank pulley but if set up properly it works fine.
sum guy
04-24-2012, 06:10 AM
This is interesting. You have your pressure and return together. probly have to run a pump for return. Good thing if you ever removed turbo it would be ten minuites to return to stock.
Lingenfelter GM LS1, LS2, LS3, LS6, LS7 Oil Cooler Adapter Kit
69-chvl
04-24-2012, 06:37 AM
I know its a 90*, but so far so good. I used one of those bolt-on flanges, all -10 stuff
http://i134.photobucket.com/albums/q116/VGIORDANO_2007/IMG_3463.jpg
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
